opti install
Go down to your local hardware store and buy a 1 inch screw with a T15 torx head. Put the screw in small vice grips or pliers and you have an opti tool. Buy 2 screws as they are cheap. I had to grind down the head a little to get it to fit into the recess in the opti. Some people weld them onto an old screwdriver for a more permanent tool.
The stock screws that hold the TB plate on will work as a tool for the opti, but you will probabay wreck the threads. I brazed one of them into an old small socket to make a tool. Normal torx socket will not reach far enough into the hole.
If you're in a hurry - SnapOn or Sears, and bring lube...
should i do any thing to the opti before i install it?any info on installing it would be great.thanks
Sergio
Jan 27, 2016 04:27 PM
