opti install
Old Jun 12, 2008 | 01:56 PM
ARZ28's Avatar
opti install
should i do any thing to the opti before i install it?any info on installing it would be great.thanks
Old Jun 12, 2008 | 03:20 PM
marshall93z's Avatar
Make sure the rotor screws are tight. Some people loctite them. I have never had a problem with them backing out.
Old Jun 12, 2008 | 04:30 PM
Pontiac_97's Avatar
maybe run a small bead of RTV sealant where the two halves of the opti come together. put some type of thread locker on the two rotor screws. i think the blue locktite will work just fine
Old Jun 12, 2008 | 05:44 PM
ARZ28's Avatar
do you know where i can find one of the small torx sockets to get it apart
Old Jun 12, 2008 | 07:17 PM
deliryumtrigger's Avatar
I got mine at Sears... but I swear I saw some the last time I was in an Autozone and wondered why I drove an extra 15 minutes to get to the nearest Sears
dubbsix's Avatar
Try Sears. My kit came with a shallow socket, but you'll need a longer one.
Old Jun 13, 2008 | 02:33 PM
bobdec's Avatar
Go down to your local hardware store and buy a 1 inch screw with a T15 torx head. Put the screw in small vice grips or pliers and you have an opti tool. Buy 2 screws as they are cheap. I had to grind down the head a little to get it to fit into the recess in the opti. Some people weld them onto an old screwdriver for a more permanent tool.
Old Jun 13, 2008 | 08:16 PM
JP95ZM6's Avatar
The stock screws that hold the TB plate on will work as a tool for the opti, but you will probabay wreck the threads. I brazed one of them into an old small socket to make a tool. Normal torx socket will not reach far enough into the hole.
Old Jun 14, 2008 | 12:21 AM
sbs's Avatar
sbs
If you have time to wait, Amazon carries a fairly cheap one.
If you're in a hurry - SnapOn or Sears, and bring lube...
Hard to say without knowing what model & year of car or brand of opti.
Old Jun 14, 2008 | 09:48 AM
JP95ZM6's Avatar
If you go the Sears route etc and cannot find a long reach socket, you could probably also grind a normal length 1/4 socket down to make it thin enough to reach into the hole.
Old Jun 14, 2008 | 11:43 AM
Pontiac_97's Avatar
i got mine from autozone. it took a little searching since it was all by itself on the shelf of tools they have
Old Jun 14, 2008 | 08:50 PM
ARZ28's Avatar
thanks for the advise. i just went done to home depot and grabbed a three inch decking screw and gound it down a little to fit in hole and it worked fine.thanks again.
Sergio
Jan 27, 2016 04:27 PM
maybe2fast
Mar 16, 2015 11:59 AM
GigaMp3z
Feb 20, 2003 02:57 PM
