OPTI failing, thinking of new system.....
Old Nov 10, 2009 | 09:34 PM
  #31
remaxracer45's Avatar
ended up getting a new msd from a place in Florida for $430.00 shipped will let ya know how it goes, also like to have the timing adjustment for n/a verses nitrous.
Old Nov 10, 2009 | 10:09 PM
  #32
93camaroLT1's Avatar
Originally Posted by charliediss
I really REALLY shouldnt be saying this but my first opti made it 150,000 miles
I'm still running a factory 93 non-vented opti on my car. They're not that bad if you just don't ever drive your car out in the rain or snow.
Old Nov 10, 2009 | 11:08 PM
  #33
some people have real good luck with them I had a 97 ss that had 100K before it needed to be changed
Old Nov 27, 2009 | 03:40 PM
  #34
roadrocket1's Avatar
did the opti I sent you work ok?
Old Nov 27, 2009 | 04:24 PM
  #35
RACEON's Avatar
Originally Posted by Injuneer
You don't have an Opti problem. Something else is screwed up, possibly the install.
Install is very important. If you search around, the seals for the timing cover have many issues if not installed correctly. GM even had special tools that most hotrodders have gotten around by being smart about it and once installed no leaks. The water pump drive gear is famous for leaking, yet can be installed correctly with just a simple tool made out of a sharpie.
Also,a bad water pump can cause this seal to leak if the bearings are going bad and it wobbles just a little.
The Opti also needs proper alignement and ensure the dowel goes in the right spot and without forceing it.
Also, LTCC is a very good product, with great reviews, but you still need the opti sensor portion of the opti to work.
Old Nov 27, 2009 | 04:32 PM
  #36
put on the msd unit and love it, seems to be far better quality and yes I loc tited the rotor
grgguy
17
Feb 23, 2015 07:57 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Injuneer
Dec 15, 2014 09:36 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
