opti/distributor seal?
Old Sep 23, 2006 | 11:33 AM
camzaro28's Avatar
was going to install the opti today, but ran into a problem. went to advance to get supplies needed adn they didnt have the opti seal. said it was a dealer part only. so go to the 2 closest damn GM dealers and neither parts/service dept is open on saturdays.
? is how important is the opti seal?
i dont know what it is, just went to a link i found for parts needed and it was in there. here is the link i am going by
http://www.houston-f-body.org/tech/optispark/
Old Sep 23, 2006 | 12:02 PM
Projectz28's Avatar
Moderator
Re: opti/distributor seal?
you dont have to change the seal to make the swap but its a $10 item and its just not worth taking a chance on. You should change the seal with the opti, but if the seal is fairly new you can probably let it ride. If its older then just wait till you can get the new seal.
Old Sep 23, 2006 | 12:04 PM
camzaro28's Avatar
aight that is the answer i wanted
i will wait till monday then.
thanks
colts0455
Sep 27, 2015 01:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
95mysticta
Aug 20, 2015 07:43 PM
86z28original
3rd Gen / L98 Engine Tech
Aug 20, 2015 12:20 PM
Bails098
Aug 17, 2015 05:15 PM
