Opti direct ignition, YOU"VE GOT TO HAVE ONE OF THESE!
Old Oct 10, 2004 | 12:53 PM
  #76
popsz28's Avatar
Re: Opti direct ignition, YOU"VE GOT TO HAVE ONE OF THESE!
[QUOTE=Maldo]Sorry but i can not talk about the stage 2 yet
trust me everyone here will be the first ones to know .....
WELL HOW LONG TILL WE KNOW THEN?
Old Oct 10, 2004 | 01:24 PM
  #77
Maldo's Avatar
yes it sounds like you need one of the delteq's
Even though i like selling the opti direct systems ... and before you spend your money make sure it's the opti that’s giving you the problem ... because there are other things that can cause the car to run bad but it you have narrowed it down to a opti as the culprit then my system would be the perfect upgrade to get rid of your opti problems and high speed miss etc
Send me a pm if interested with your phone numbers or you can call to order
thx Jim.
Old Oct 10, 2004 | 03:09 PM
  #78
madhatter's Avatar
Will you explain why you think your product is better than the other "product" that is out there?
Old Oct 10, 2004 | 03:11 PM
  #79
simple's Avatar
Originally Posted by simple
ok and is that module just the standard module used on the Northstar engine?
is there any special wiring i would need to do when piecing this together?
or is it all i need to do is find coilpacks, ignition module and buy the barebones kit, then plug it in to the Delteq "opti-box" and go?
as much info as you can spew out to me in setting up the system starting with the bare bones setup is the info i am looking for
thx
Steve
could i get some answers to my questions?
Old Oct 10, 2004 | 08:02 PM
  #80
TCAL95Z's Avatar
RE & Cheryl,
How was routing the plug wires with your mounting location?
I would like to get one of these but I don't want to mount it on top of the valve cover.
Did you get the wires to cut yourself?
Also, is it possible to not put the opti on at all or is that the stage II kit?
Old Oct 12, 2004 | 03:09 PM
  #81
99BlackTA's Avatar
I want Stage 2 when does it come out? You have to give us an estimated date before we go for other options...
Old Oct 12, 2004 | 03:12 PM
  #82
simple's Avatar
i would like that setup also but am in need of something right now!
will the stage1 Delteq be upgradeable to the stage 2 when it is released? thats what i want to know
Old Oct 12, 2004 | 03:14 PM
  #83
99BlackTA's Avatar
I want to throw the opti off the nearest bridge!
Old Oct 13, 2004 | 06:30 AM
  #84
97FormulaWS-6's Avatar
Thx Jim
That's OK, I have another source for information that I promised not to divluge...
Old Oct 13, 2004 | 10:09 AM
  #85
Type_O_Negative_1320's Avatar
I have about 1000 miles on my Delteq so far and I'm loving it. I couldn't find any NGK TR55s at the store I usually buy them from, so I settled for some cheapie AC Delco plugs. No problems at all...no misfires, no nothing. I ran the car on the dyno...the first four pulls were rich as hell (some dropped way below 10:1 AFR) since we were still working out the tuning. No problems there either...the same plugs are in there now, no misfires or anything. All the problems I've ever had with the opti and the stock coil are gone.
If you haven't bought one of these yet, either buy one or start saving for one. This is the best mod I've ever done to my car, hands down.
Old Oct 13, 2004 | 11:18 AM
  #86
DAVE00's Avatar
I know there is not much info about the Stage 2 but I am considering getting this setup, but I want to know if anyone knows any rumors on this new Stage 2 and what the differences will possibly be? Should I wait unit the stage 2 comes out to get it instead of the stage 1? Let me know what you know.
Thanks,
Dave
Old Oct 13, 2004 | 01:16 PM
  #87
Maldo's Avatar
hi i also sell ngk plugs let me know if you need some
Old Oct 19, 2004 | 11:39 AM
  #88
Maldo's Avatar
Hi Guys,
Just wanted to show you our lastest install and using our new powered-coated brackets (I made a house call for (Bruce Ensworth’s who has a beautiful 95 convertible z28 (http://www.rivercityf-bodies.com/ (he is our local f-body Club President)
We did not use the colored wires because we will show that later with a header install…. These pictures will be updated on my web site with details to go over the install….. I just wanted to get the pictures out to show how easy these units install….
http://www.ofoto.com/BrowsePhotos.js...d=183034469103
THX Jim
Old Oct 19, 2004 | 01:40 PM
  #89
anaik's Avatar
Hi Guys,
THX Jim
Will the system work with LT4 valve covers?
Old Oct 19, 2004 | 02:00 PM
  #90
Maldo's Avatar
Yes it will work. They also work with the early corvette valve covers.
Jim
