Opti/Cap & Rotor same thing??
Old Apr 2, 2005 | 05:24 PM
defbear's Avatar
Hey guys I'm a bit confused. Is the Opti-Spark a seperate unit then the Cap/Rotor?? Is it just another name for the Cap/Rotor? The reason I ask is because in my new Hot Rod mag there is an ad for MSD LT1 Cap/Rotor but it looks like the whole unit that you plug the wires into. Which I thought was the opti. Hope you can clear this up for me. Thanks
Old Apr 2, 2005 | 07:36 PM
Re: Opti/Cap & Rotor same thing??
The Optispark is the distributor. It has two parts.... the front 1/2 is the cap and rotor (plug and coil wires connect to it, just like any other distributor). The back 1/2 is the housing, bearing, bearing retainer, slotted optical wheel, optical sensor and harness connector. The cap/rotor dies in about 70% of the cases, the rear section the other 30%.
The MSD replacement is only the cap and rotor.
Old Apr 3, 2005 | 01:53 AM
defbear's Avatar
Ah I see. Thank you very much!
carguy0119
Apr 11, 2016 11:11 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
ScottZ
Mar 3, 2004 01:34 PM
Hal Fisher
Sep 14, 2002 09:36 PM
