Open headers?
Old Oct 31, 2004 | 02:06 AM
Z-RATED94's Avatar
Open headers?
If a car has a dynotune while running thru an exhaust system, is it OK to run open headers at the track or would it run to lean? Anybody ever try this and do you have any results you could share?
Old Oct 31, 2004 | 07:09 AM
97Z-M6's Avatar
Re: Open headers?
i tried this with long tubes and found the car runing rich because the o2s are to close to end of the colector and fresh air from the outside will swirl in and and hit the o2s and give you a false lean a the pcm will start dumping fuel and you will run exremly rich.
just put a 12" peice of pipe on each colector and that will solve your problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
jasonduaine
Apr 1, 2015 08:09 PM
Cam's maro
Jan 30, 2015 09:21 PM
