Opti Dead inside of 7000 miles
Old Oct 30, 2004 | 03:47 PM
94Sleeper's Avatar
Angry Opti Dead inside of 7000 miles
When I built my new motor last year I converted to a 95 style vented Opti and installed a brand new unit. The car ran great until last week when it died very suddenly on the way home. I was accelerating in second pretty hard when all of a sudden a stumble and no power. I just got a chance to look at it today and I have lots of spark going into Opti but nothing at the plugs. The rotor inside must have broke.
I know there can be some issues with the cam dowel length so when I assembled the motor I measured it and it was about .620”. It really frosts my tail that these things can go Tango Uniform inside of 10,000 miles.
Anyway had to vent (no pun intended).
Old Oct 30, 2004 | 03:59 PM
ssbowtie1's Avatar
Re: Opti Dead inside of 7000 miles
If its within a year you should be able to get a free replacement.
Old Oct 30, 2004 | 06:26 PM
94Sleeper's Avatar
I bought this Opti from Jason C in the Spring of '03 so I guess I'm out of the warranty period.
Old Oct 31, 2004 | 01:53 AM
Z95m6's Avatar
The rotor probably broke. A friend broke his the same way, running it hard.
Old Oct 31, 2004 | 05:52 AM
amean94ta's Avatar
i have one with 5k on it going to delteq since you had bad luck its yours for $150 shipped
Old Oct 31, 2004 | 07:28 AM
You still need an opti to run the Delteq.
Old Oct 31, 2004 | 07:39 AM
slopokrodrigez's Avatar
When you converted to the vent, did you position the hoses correct with the vacuum restrictor? If not, you may have sucked the cap down into the rotor.
If the rotor and cap went south but the optical encoders are in good shape, you can convert to the Delteq.
Old Oct 31, 2004 | 08:23 AM
amean94ta's Avatar
yes i know but i am gonna use my 94 non vented one this one i am selling i bought to do the vented conversion. which i do have all lines and timing cover for anybody that needs them
Old Oct 31, 2004 | 08:40 AM
94Sleeper's Avatar
When converting to the Vented Opti I bought the set of hoses which have the the restrictors already installed installed. The hoses are different sizes and only fit properly on the vented opti one way.
Old Oct 31, 2004 | 08:49 AM
Where did you get the vacuum source from? I believe they have to be from 2 different locations so there is a pressure differential. This creates flow. If they are both from the same location (pressure wise) there's your sign.
The stock hook up uses the intake elbow as one point and the intake manifold as the other. Just trying to figure this one out.
Old Oct 31, 2004 | 09:17 AM
94Sleeper's Avatar
Intake air is from my air intake elbow and the vacume is from the intake manifold. I'm resonably confident that the vacume hoses are installed correctly.
*Emilia*
May 13, 2015 09:05 AM
nikolt1
Feb 27, 2015 09:10 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
capebuf
Jan 13, 2015 07:22 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
