OMG Cant Drive Car!!!!
Old Mar 28, 2003 | 01:49 AM
  #16
anasazi's Avatar
Originally posted by JulietZ28
but i have no power loss. if i had a blown head gasket wouldnt i loose compression in 1 or more cylinders?
its something simple, bleed the system, run it without a thermostat one time just to see if that fixed it, check to make sure the coolant is being circulated, check simple stuff first.
Old Mar 28, 2003 | 05:11 AM
  #17
94F1Z28's Avatar
Originally posted by carnutz
Guys think about it!!!! I have seen this many times, pushing coolant out the over flow and the heater doesnt blow hot. Sounds like a classic head gasket, compression in the cooling system, sounds like time to some serious investagating. Maybe I'm way off but those are 2 major sighns.
I agree because i have had this problem on a couple of different cars.
Old Mar 28, 2003 | 02:54 PM
  #18
JulietZ28's Avatar
ok guys new development. Im replacing the 160 thermo with a new one just to be sure its not that, and my old 160* has 3 prongs on the top and my new one has 2 WTF which one is the real 160? could this be part of my problem??
Old Mar 28, 2003 | 03:13 PM
  #19
TheHeadFL's Avatar
Sounds like a Small Block Chevy thermo maybe?
Old Mar 28, 2003 | 04:05 PM
  #20
Prongs don't matter, just make sure it is a long thermostat designed for the LT1.
Old Mar 28, 2003 | 04:09 PM
  #21
My95Z's Avatar
make a manual fan switch, someone probably already said theis but I am do lazy to read all the posts
Old Apr 1, 2003 | 10:08 AM
  #22
JulietZ28's Avatar
ok so i took it into the shop and told them it was either a clogged heatercore or a headgasket/ cracked head. And they couldnt get it to overheat I picked it up today and the heater blows hot air and it runs fine. Now i dont know when its gonna leave me stranded again. Guys plz help. What can i do??
Oh yeah, the fans are on. I checked a couple days back when it was overheating bad and the fans were on full blast.
Old Apr 1, 2003 | 10:53 AM
  #23
RENE95Z's Avatar
I'm with Shoebox on this one, you probably had an air pocket in there that was giving you the problem. I experienced the same thing when I was flushing the system and didn't know anything about the bleeder valves at the time. Car got real hot real quick. Thought it was the thermostat so I replaced it. Found out about the bleeder valves and no more problem. At least I know I have a new thermostat now.
Old Apr 1, 2003 | 11:54 PM
  #24
jwar19's Avatar
I've yet to bleed the system on my car, so I have to do it. Before I do, are there any precautions I need to take? Do I bleed it with the car running or while the engine is off?
Old Apr 2, 2003 | 12:04 AM
  #25
Kain's Avatar
Running and hot. Bleed it from the two little screws between the water pump and radiator on different tubes.
Old Apr 2, 2003 | 12:36 AM
  #26
Lost's Avatar
Overflow tank should be full, radiator cap securely on.. car at operating temp.. then open the bleeder valves and wait for all air to exit the system.
NOTE: stuff some rags around to keep any coolant from running down onto the opti! GM sure did a great job placing a water sensitive sensor right below the water pump
Old Apr 2, 2003 | 03:00 AM
  #27
chasmanz28's Avatar
could be air in the system if its not bleeded right it will do that
Noenav
Mar 1, 2019 07:38 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
