View Poll Results: Do You Think His Opti is gone??
YES!! DUHH!!
38.10%
No!!!!
19.05%
I don't know it could be something else....- list what you think
42.86%
Voters: 21. You may not vote on this poll
OMG all of my LT1 drivers that has had to replace a opti please come in here!!
Old Oct 12, 2007 | 11:26 PM
SinisterSix's Avatar
my friend has a 93 z28 he has brand new spark plugs , and wires.. the car is getting gas but when he tries to crank it .. it will not turn over and it back fires ! i have showed him a bunch of threads about what happens when the opti goes bad. .
he still don't believe me that..the Opti is his problem! What do you think?? do you think it's his Opti?!?! the car had over 120,000 miles on it!..
Old Oct 12, 2007 | 11:29 PM
bombebomb's Avatar
Question: How does it not turn over, yet it back fires?
Old Oct 12, 2007 | 11:37 PM
it back fires wile trying to turn over.. (wile the starter is turning the crank)
Old Oct 12, 2007 | 11:46 PM
Stl94LT1's Avatar
Any codes?
Old Oct 13, 2007 | 01:09 AM
a walker's Avatar
If the engine spins when the key is turned, it is turning over.
Old Oct 13, 2007 | 01:17 AM
i meant to type it not starting my bad.. it is turning over
Old Oct 13, 2007 | 01:20 AM
raroz28's Avatar
its not hard to test the ignition system and find out exactly where the problem is.
It could be opti, coil, icm, etc...
Old Oct 13, 2007 | 10:16 AM
93 its easy to flash the codes on the SES light.... why not start there rather than to take a poll on the Internet?
Have you ruled out things like:
-coil
-IC Module
-corrosion in Opti plug and coil wire terminals
-corroded Opti harness connectors
Does "getting gas" mean that he has verified the fuel pump will prime the system when the key is turned on, then shut down, waiting for the engine to start? Does that mean he has verified that the injectors are firing when it tries to start? Has he verified that the injectors are not leaking and flooding the engine, preventing it from starting? Has he tried putting the accel pedal on the floor to put it in "clear flood" mode.
Old Oct 13, 2007 | 11:43 AM
-coil
-IC Module
yes... i dont think he has checked the ic module
Old Oct 13, 2007 | 09:53 PM
95 Civic's Avatar
its sounds like a opti... but if you know anything about LT1's, DO NOT CHASE THE PROBLEM, or trial and error the problem(I found out the hard way). I am a service advisor now and trust me, it will cost you less to just get it diag. from someone else and do the work afterward, or even have them do it.... take your pick.... $50-$100 for a diag... or just throw a part up to $300-$400(or maybe cheaper), do the labor, and hope it fixes it.... take your time...
Old Oct 14, 2007 | 02:19 AM
TobyZ28's Avatar
Eh im all for diagnosing the problem but a lot of shops absolutly suck at diagnosing these lt1's
This does sound like the typical opti. IF the problem was there before and after the new plugs its almost for sure the opti. 250$ for the opti from jason/dal and i think the ICM is around 50$.
Old Oct 14, 2007 | 03:05 AM
96LT1TX's Avatar
If the problem started after isntalling the new plugs and wires, the problem is that one of the plug wires is installed on the wrong number on the opti. Check all the wires to make sure that the #2 wire goes to the #2 on the opti... I crossed a whole side backwards once and it did that. HTH
Old Oct 14, 2007 | 10:04 AM
95 Civic's Avatar
OMG! We switched two plug wires once after a motor swap... that was the worst couple off days. "It could have been anything after a motor swap" and it turned out to be that....
Old Oct 14, 2007 | 10:05 AM
JoeliusZ28's Avatar
what i was thinking. missplaced wires.
Old Oct 14, 2007 | 11:54 AM
maybe2fast's Avatar
x2
