OMFG!!!!!! its alive
Old Apr 21, 2004 | 02:26 AM
  #16
MentalCaseOne's Avatar
i made the plug wires
I would check the Coil to Opty wire.....
Marvin
Old Apr 21, 2004 | 10:51 AM
  #17
1994TransAm's Avatar
got it guys,
i started to tink... my opti is new..... icm and coil are newish...fuel pump was fine before.....
when the car did start it had a bad idle...choppy and it would jump and rev....... this just popped into my head
vaccum leak>rpm fluctuates>dies on idle
looked for my vaccum leaks..... found it.....
it was the evap line to the TB... it was missing... musta forgot it....
why would my car run in the first place though...... what does the evap do
Old Apr 21, 2004 | 11:37 AM
  #18
Tony Danza's Avatar
so it runs fine now??
Old Apr 21, 2004 | 12:41 PM
  #19
dammit..... that didnt work... i just tried to start it again ... no dice
Old Apr 21, 2004 | 02:03 PM
  #20
schpenxel's Avatar
Well, are you smelling gas, have u pulled some plugs and looked at them, have u tried starting fluid, have u hooked a timing light up to some plug wires to see if its firing?
Old Apr 21, 2004 | 03:48 PM
  #21
Naegash's Avatar
Make sure you didn't move the intake manifold gaskets around when you set the intake back on. Happened to me one time, I saw one gasket sticking about 2" out of the back of the engine. It didn't run very well
Old Apr 21, 2004 | 03:55 PM
  #22
Kryckter's Avatar
Its actually very easy to flood one of these cars out, Dont start it the first second or thrid time but keep trying to start, It will flood the plugs very fast. Odds are that if you try to put it in clear mode when starting its too late. Check some plugs, They are probably soaked in gas! Replace them and start over again!
C4m4roJoe
Jul 19, 2015 10:59 PM
crAzy95z28
Dec 29, 2003 05:48 PM
silicuda
Pacific
24
Jun 9, 2003 11:03 AM
InjectedSS
Jun 6, 2003 07:06 PM
silicuda
Pacific
49
Mar 13, 2003 04:51 AM
