OMFG!!!!!! its alive
Old Apr 19, 2004 | 05:36 PM
1994TransAm's Avatar
hey guys,
just started the car...... oil pressures at 50 psi. CSI is running and no coolant leaks or anything like that,.
MAN THE 847 SCREAMS!!!!!!!!!!!!!!!!!!!!!!1
i have a vidoes and stuff.....
Old Apr 19, 2004 | 05:57 PM
drewstealth's Avatar
Good to hear that your car is running.
Now we need to see some 1/4 mile times and some dyno #'s from that thing.
Old Apr 19, 2004 | 06:05 PM
Valkyn71's Avatar
Old Apr 19, 2004 | 06:33 PM
95_LT1_6SPD's Avatar
dont tease us by saying you have video and not posting
Old Apr 19, 2004 | 06:40 PM
cndctrdj's Avatar
NICE now put up the vidoes
Old Apr 19, 2004 | 06:45 PM
Cmr0z28's Avatar
Originally posted by Valkyn71
Old Apr 20, 2004 | 06:05 PM
well guys teh cars dead in the water!!!!
it will turn over but not start!!!!
i dont get it...
i had code 33...so i put in a new map.... now it wont even start!!!!!
i've pulled the fuse for pcm....... nothing...... could it be my pump? i dont hear it pressureize every time!!!
Old Apr 20, 2004 | 06:13 PM
ibanez6rg's Avatar
Check your fuel pressure... getting spark?
Old Apr 20, 2004 | 06:15 PM
this is a new opti....... i made the plug wires.... but everything should be firing... i dont get it... i had it runing 30 mins ago
..... now nothing!@!!!kfashgdkh
Old Apr 20, 2004 | 06:18 PM
trev0006's Avatar
video please
Old Apr 20, 2004 | 10:03 PM
schpenxel's Avatar
Did you hook up all the sensors, and Y pipe, i flooded mine right after i started the motor cause it was running rich, 02's were too close to atmosphere bc of no Y pipe, also didnt have the coolant sensor hooked up so it was even richer, anyways, just a guess, starting fluid is your friend
Old Apr 20, 2004 | 10:33 PM
my94blackz's Avatar
Floor the gas pedal while your trying to start it. I know it sounds stupid but thats the only way mine fires sometimes.
Old Apr 20, 2004 | 11:36 PM
schpenxel's Avatar
WOT at startup=no fuel from my understanding, good way to clean off the plugs
Old Apr 20, 2004 | 11:44 PM
thanx guys.... gonna tear into it tommorw night..... stupid car!!!!
Old Apr 21, 2004 | 01:45 AM
TUFF LT1's Avatar
Petal to the floor when starting = Clear Flood mode. It cuts off all fuel to the motor. Give it a try
