OLD school sbc into 94 camaro?
Old Apr 17, 2009 | 07:31 PM
detroit1994z28's Avatar
I'm looking to maybee put a old sbc into my 94 camaro z28. I was wondering if it's allot of work. What's everything that I will need. I wanted to run my stock t56 with it? Will everything just bolt up. Is this a costly project?
Old Apr 17, 2009 | 10:10 PM
jclark311's Avatar
I have not done it, but I think its just a bolt in, the bellhousing pattern is the same, so the trans should be no problem. I am assuming you are running a carb, so you rip out the computer and harness, the fuel line wont lineup, but you can cut that under the car, and splice in a new piece, the gas tank has an electric fuel pump in it, you can use it, and put a block off plate on your motor. I am not sure if you would have to regulate the fuel pressure, I think not, because its carb, but you might have to buy something, to make a return to the tank! LT1's were capable of putting in a distributor, so you should have firewall clearance, but I wouldnt run that stock GM HEI distributor that has the coil on the cap, I would go with an aftermarket, so you dont hit the firewall when trying to time it. Good luck.
Old Apr 18, 2009 | 10:36 AM
The Gen 1 engines do not bolt up to an LT1 T56. There is a kit available.
You can't run a carb with a 45psi fuel supply. Definitely need a pressure regulator. The return line is already there for a bypass style regulator. A lower pressure pump would be a better solution.
Why would the fuel line "not line up"? Its got about 3-feet of plastic tubing after it comes out of the driver's side fender well.
It isn't firewall clearance that's a problem with a conventional distributor, its the cowl. Some people have cut out the cowl and the wiper linkage for clearance, others have found distributors that will fit.
Going to a Gen 1 block does not mean you have to go to a carb and a distributor. It can be injected and have a fully computer controlled direct-fire ignition.
But you need an aftermarket ECU, or to keep the LT1 PCM, you need to find a way to mount the optical sensor from the Opti either on the front of the engine, or using a distributor stub. It has been done.
Old Apr 18, 2009 | 11:40 AM
Chevyguy358's Avatar
you may want to look at msd's pro-billit low profile distributor...
Old Apr 19, 2009 | 12:00 AM
daddy_rabbit08's Avatar
where can you get this kit because i'm in the same boat? and what did you do about the motor mounts?
Old Apr 19, 2009 | 11:06 AM
If you mean the kit to fit the LT1 T56 to a Gen 1 block, check with Spohn Performance. Steve Spohn borrowed my spare LT1 T56 to help design the kit. He doesn't make the kit, but he knows who does.
Old Apr 19, 2009 | 11:07 AM
mdacton's Avatar
its still a very very tight fit.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
GhostZ28
Dec 7, 2014 11:53 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
