Okay Guys! I'm really Stumped now!
Old Oct 22, 2003 | 01:08 PM
LeeS's Avatar
Unhappy Okay Guys! I'm really Stumped now!
Hi Guys!
I have a 1997Z28. 76Kmiles
Problem: It makes a popping noise in the exhaust while idling and the idle is a little rough.
Things I have Done: Replaced Opti-Spark, Spark Plugs and WIres, Replaced EGR Valve, Checked Fuel Pressure 39-40psi Idle and 46psi WOT. No Vacuum Leaks. Cleaned the Throttle Body and Mass Airflow Sensor.No Burned wires or Bad Plugs. Plugs are AC Delco!
What do you Guys Think I should do next????????????
Thanks Lee! You Help is Truly appreciated.
Old Oct 22, 2003 | 01:14 PM
Gripenfelter's Avatar
Exhaust leak?
Old Oct 22, 2003 | 01:27 PM
LeeS's Avatar
Thanks for the reply!
Keep em Coming. Lee!
Old Oct 22, 2003 | 01:31 PM
joeSS97's Avatar
Yeah, what Grip said.Any codes?How bad is the popping?
Old Oct 22, 2003 | 01:35 PM
Your 97 OBD-II has misfire detection capability. Get a scanner on it. You should be able to retrieve the misfire counts for each cylinder. That will point you to the problem. Might be something like a bad injector, or a sticky valve.
Old Oct 22, 2003 | 02:07 PM
LeeS's Avatar
Thanks Guys for your help!
It doesn't pop real bad just every non and then.
If you ease down on the gas to like 1500rpms it is still studdering and popping a little after that it disappears.
Injuneer!, What would be the best scanner to buy?
I think I need to invest in this!
Thanks Lee!
Old Oct 22, 2003 | 03:05 PM
LeeS's Avatar
Any one else want to comment!
Old Oct 22, 2003 | 03:07 PM
FacelessZ's Avatar
Sounds like an exhaust leak...very prominent in our cars...mine is doing the same thing right now...
Jessie4tin
Jan 7, 2015 08:53 AM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Red97LT1
Aug 7, 2002 05:45 PM
