Ok, so I temp mapped my heater core
Old Nov 8, 2007 | 07:22 PM
Red96Lt1's Avatar
I've been having problems with my heat this winter. It will blow out luke warm air. I checked the coolant level, and made sure there was no air in the system. Everything was ok. So tonight I removed all the panels to get to the heater core and did a little test. Here was the procedure:
-Warmed car to temperature
-Turned on cooling fans on high to maintain a constant coolant temperature
-Turned heater on high, left on for 15 minutes to achieve steady state
-Outside temp = 54°
-Coolant temp = 190°
Here is a temperature map of the heater core
Top
79 123 120
Driver 81 118 143 Passenger
95 125 155
Bottom
So my question would be, is it clogged up and therefore need to be flushed/replaced
Old Nov 8, 2007 | 08:23 PM
MeanGreen97Z's Avatar
I'm having a similar issue. I'm interested to see what people have to say.
Old Nov 8, 2007 | 09:39 PM
Dwarf Killer's Avatar
I'm also having the same issue. Changed the heater core and the thermostat, flushed system. No difference. Checked heater flaps under the dash, all working properly. No air pockets either.
I looked for the heater core valve some say they have but I don't have one. I do however have a T intersection some have told me is a clogging problem so I will check that out. The inlet hose seems warm but not hot so I'm guessing there's a flow problem somewhere.
Old Nov 8, 2007 | 10:07 PM
1racerdude's Avatar
There is/was a flow restrictor in the inlet hose near the firewall.
It may be the problem. I think it just pushes in the hose but good luck getting it out.
Old Nov 8, 2007 | 11:40 PM
You did an awful lot of work. I would have just flushed the heater core and observed what the heat was now like. Flushing solves 90% (or higher) of no heat complaints.
Old Nov 9, 2007 | 08:01 PM
Flushing didn't work. Problem has to be inside the hoses. None of the traditional solutions work on this car. The cooling system is unique, and the hose system/regualtor is likely the culprit as witnessed by others.
Old Nov 9, 2007 | 08:03 PM
shoebox did you mean flushing the heater core individually or for him to flush the entire cooling system?
Old Nov 9, 2007 | 08:59 PM
TobyZ28's Avatar
I'm sure he meant the usual way of flushing just the core with hose. Best way is to flush it one direction then the other and repeat a few times until it flows nicely again.
Old Nov 9, 2007 | 09:29 PM
I flush the heater hoses when I flush the core. IMO, it is the only logical way to do it.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
tdigger9899
Sep 7, 2015 10:56 AM
FredM
Aug 14, 2015 01:49 PM
4586
Aug 13, 2015 10:11 PM
ducttape1975
Jul 10, 2015 06:29 PM
