ok guys got another question
Old Aug 21, 2008 | 09:27 PM
texastransam96's Avatar
ok i have been chasing a bad idle, and after putting it on a scanner and reading the codes, and checking circuit levels we found out that my tps although new had been broken during the install( before i bought it). i also got a code p0336, but thought it was possibly due to the bad tps causing a miss...
well i was wrong. i changed the tps and now it will idle perfectly fine, but once warm it kind of gets a bit of a slumping idle, and when i am driving for about 10 min or so, it will start to cut out, even killing the car while driving. i let it sit for a few minutes and it starts right back up.. and will run till it feels like dyin'. i put it back on the scanner and is saying bank one sensor one low voltage (i got a new o2 sensor to fix that), but it is still throwing that p0336 code (crank position circuit malfunction). with the symptoms i have described above, would it be safe to say that my opti is going out? the car has a brand new wiring harness on it, so no wires are corroded or anything of that nature ...
Old Aug 22, 2008 | 01:02 AM
mrmint69's Avatar
Doing a search it appears the opti is the likely culprit.
Old Aug 22, 2008 | 07:31 AM
thanks... did some searching on here myself, and came up with the opti, or fuel pump as far as symptoms go, but with that code was leaning more to the opti, just wanted to ask and see what people might think.
Old Aug 22, 2008 | 08:52 AM
ulakovic22's Avatar
Yep, sounds like Optispark to me. It can cause all sorts of wierd malfunctions when it's on it's way out.
Old Aug 22, 2008 | 10:54 AM
slomarao's Avatar
+1 on the opti. Maybe something small but most likely its the opti. Chech the coil.
Old Aug 22, 2008 | 01:30 PM
yeah i recently replaced the coil,icm, plugs and wires hoping for it to be that but it doesnt look like i am going to luck out this time
Old Aug 22, 2008 | 09:55 PM
Check the Opti harness connectors for corrosion or bent pins, before you decide to replace it.
Old Aug 22, 2008 | 10:00 PM
i just checked that as well... i recently put the new engine harness on it (problem had started before putting this on), and while it was off i looked into that hole to check for any corrosion and didnt notice any bent pins.. one thing i will mention is that the guy who had built this car decided he wants to leave the vacuum lines off of the opti and just plug the side port in the intake, so i am assuming that some moisture or something might have got into it through those holes to cause the possible early exit for the opti
i would assume that the vacuum lines being off wouldnt be a good idea would it ?
sscott
Jan 17, 2015 04:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Red97LT1
Aug 7, 2002 05:45 PM
Brent94Z
Mar 21, 2002 04:44 PM
