Oil temp gauge install
Old Jun 2, 2007 | 08:20 PM
sleeper94z28's Avatar
I've got a quick question for you guys, where is the best place to install an electrical oil temp sending unit on a 1994 camaro? My PaceSetter LTs already pretty much touch the pressure sending unit so installing an adapter or elbow is pretty much out of the question. I noticed a plug behind the manifold when I had it off and I think thats where 1995 up F-cars use it, but I with the manifold on thats gonna be tricky to get to. Do yall have other better ideas?
Old Jun 2, 2007 | 09:00 PM
windsma's Avatar
that plug behind the manifold is where every old chevy motor was tapped for an oil pressure gauge. I think it would work, I kinda have a similar issue when pulling the motor out my popps twisted the motor a broke my oil press. sensor on the side. can i delete that or do i have to buy another one.
Old Jun 3, 2007 | 11:03 AM
I drilled and tapped the oil drain plug to accept an oil temp sending unit. Put a connector in the wire so it can be unplugged to drain the oil.
Old Jun 3, 2007 | 11:37 AM
2000GTP's Avatar
That is a pretty clever method of doing it Fred.
Old Jun 3, 2007 | 01:34 PM
OBE1 95Z28's Avatar
Shoebox has a good photo of the location on the block behind the manifold here: http://shbox.com/1/op_sensor.jpg
Old Jun 3, 2007 | 10:54 PM
Sounds like he has an "early" 94, and he already has the stock oil pressure sensor in that location. He mentions he has a problem with his headers hitting the sensor, and that he has a plugged hole in back of the intake, where the 95 (actually "late" 94 and up) sensor is located.
Old Jun 4, 2007 | 09:18 AM
OBE1 95Z28's Avatar
Hi Fred, if you were referring to my link to Shoebox's site, we're in agreement
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
GigaMp3z
Feb 20, 2003 02:57 PM
