Oil smell under high acceleration??
Old Nov 9, 2004 | 04:36 PM
ChevyTuffD.A.'s Avatar
Alright, I just dropped a new 357 in my car and right now it has about 3000 miles on it. When I start to get to speeds over about 90 or so and higher RPM's I can smell what appears to be an oil smell. Its not like a burn oil smell but more of an unburnt oil smell. I dont have any oil leaks and I dont recall ever seeing me burning oil out my exhuast. Anyone have any ideas???
Old Nov 9, 2004 | 06:19 PM
93turbo5oh's Avatar
Re: Oil smell under high acceleration??
have you stuck your hand on the back of the block under the cowl? is there any oil in the trans/block area?
Old Nov 9, 2004 | 06:21 PM
Spinner's Avatar
I get an oil smell too. From what I've figured, it's a TINY dribble from the rear main seal and is slung around and you end up smelling it in the cabin. No harm, no foul, just a little oil smell.
Old Nov 9, 2004 | 06:27 PM
I dont appear to have a leak. At least I know there isnt any dripping onto the ground. It usually only happens if I race someone to a high speed, like say over 100mph, then after the race I smell it for just a minute and then its all back to normal.
Old Nov 9, 2004 | 06:30 PM
944v8inDFW's Avatar
Have you done amy mods to the PVC or Crankcase breather system? Like a filter on the pass valve cover instead of plumbed to the throttlebody? Just a thought and that could certainly account for some oil smell.
Old Nov 9, 2004 | 06:42 PM
EricTheBald's Avatar
I would have to wonder if maybe you're getting blowby past the new rings.
I mean; the smell of oil under acceleration strongly implies that you're pressurizing the crankcase and the gasses are finding their way out; dragging an oil mist with them.
Old Nov 9, 2004 | 06:50 PM
Well its not a burnt oil smell tho. It smells like clean/unburnt oil that i am just getting a wiff of.
Old Nov 10, 2004 | 05:27 AM
slopokrodrigez's Avatar
Can you smell it outside the car as well as in the cabin? Does it make a difference if you have the HVAC fan on or not? Can you look under the inspection cover on the bell housing?
Old Nov 10, 2004 | 05:11 PM
I dont have a cat so i usually just get the no-cat smell out of the exhuast. I dont think it really makes a differance whether the fan is on or not.
ad356
Apr 11, 2015 08:49 AM
lt1matt
Mar 21, 2015 07:35 PM
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
blac94Z
Jan 12, 2015 05:44 PM
