Oil Pump and Pan Gasket
Old Jan 10, 2006 | 10:34 AM
OutsiderIROC-Z's Avatar
My oil pan gasket is leaking after the the timing chain install I had done last winter and I want to fix it.
I want to go with a one piece oil pan gasket and while the pan is off, replace the oil pump. What would be the best parts to go with and where to get them? Thanks in advance.
Old Jan 10, 2006 | 10:39 AM
RICEFEDZ28's Avatar
Re: Oil Pump and Pan Gasket
I've used the fel pro blue gasket and like it just don't over torque or it will crack.
Old Jan 11, 2006 | 07:02 AM
Thanks for your input. Anybody else?
Old Jan 11, 2006 | 07:29 AM
hey01's Avatar
just make sure you have clean mating surfaces and it should go like cake. You can use some vasoline to keep the gasket from moving around while your trying to get the oil pan in place (that is what i do with my trans gasket).
Old Jan 11, 2006 | 07:40 AM
All GM parts from Jason or Dal.
Old Jan 11, 2006 | 08:00 AM
Hotwire's Avatar
I just installed my pan gasket last night. Washed the oil pan down in my parts washer that's filled w/ mineral spirits, then used brake cleaner and a clean rag to clean off the pan rails on the block. Waited to make sure everything was dry and clean. used black rtv and ran a very small bead down the pan rails and valley on the pan, placed a new napa gasket on there, dabbed rtv in the corners of the timing cover and rear main seal on the block, then ran a very small bead around both of their valleys. installed the pan, had one hell of a time getting the pan installed, just didn't want to go.. then realized the gasket has a HOLE for the dipstick tube, not a indentation like they use to. lol, after pulling all the bolts loose and dropping the pan, running the dipstick THROUGH the hole, it went on without a hitch. I put in 5 qts, primed the motor and turned the crank several times by hand but haven't had a chance to fire it up yet. Just figured I'd share my story so you won't be loosing time over the same stupid mistake, although I'm not sure how tight it is under the z, my lt1 is sitting in a 4wd s10 blazer, so it was a little snug.
Old Jan 11, 2006 | 01:33 PM
For the oil pump I can see going the GM route, but I really want to use a one piece gasket instead of the 4 piece (I assume the LT1 uses the 4 piece??) setup.
Old Jan 11, 2006 | 01:38 PM
Hotwire's Avatar
no if you go auto zone / advance auto / napa , it's one piece molded w/ "crush" rings where the bolts go through to keep you from over torquing.
Old Jan 11, 2006 | 01:53 PM
sssalah's Avatar
The Lt1 uses a one piece oil pan gasket from the factory. I think Chevrolet switched to this design back in 1986.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
