Gear to gear
Old Jan 10, 2006 | 11:01 PM
LT193's Avatar
Gear to gear
Anyone running a gear to gear setup instead of a timing chain?
Old Jan 10, 2006 | 11:32 PM
8cylinders>4's Avatar
Re: Gear to gear
i've heard its not a good idea on a motor that is equipped with a knock module. I guess the extra noise and harmonics caused by gear driven camshafts cause the knock module to go nuts and retard you timing so unless you have a fix for that it doesn't sound like much of a good idea to me
Old Jan 10, 2006 | 11:57 PM
HardcoreRM125's Avatar
Re: Gear to gear
But if your modifying the car to the point that you need gears, you'd need a good PCM tune anyways, and you could have whoever does the PCM for you disable the knock module. I wouldnt reccomend it, but if your dead set on gears, it could be done.
Old Jan 11, 2006 | 11:51 AM
LT193's Avatar
Re: Gear to gear
Are u telling me i can have the knock module totally erased from working with just a tunE?!!!! I hate that damn thing lol.
Old Jan 11, 2006 | 12:16 PM
Re: Gear to gear
Yep.
They can totally program it out if you want them to. I am not totally sure how the tables are so that it is disabled, but I do know that it can be done. Try talking to the guys from PCMforless, Ion, or some of the other guys who do PCM's
Old Jan 11, 2006 | 12:19 PM
Re: Gear to gear
There are some negitive points to disabling it though.
If you were getting knock, your engine could be severly damaged.
When you talk to them, they could tell you the pros and cons of the whole thing and maybe point you in the right direction.
If your not going to be making absurd amounts of horsepower though, I would just suggest going to a electric water pump, and then buy the best double roller timing set you can afford.
Old Jan 11, 2006 | 04:57 PM
LT193's Avatar
Re: Gear to gear
I think im going to have that done asap, as far as taking out the knock sensor, if its not being used cant u disconnect it? After the tune? Or will it throw a light?
Old Jan 11, 2006 | 05:22 PM
1racerdude's Avatar
Re: Gear to gear
Do a search and get the details of putting it on a switch with the resistor.
Turn it on-- turn it off either way.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
