Oil pump O ring?
Old Apr 8, 2007 | 02:10 PM
tim95z28's Avatar
Oil pump O ring?
Just installed an M55 pump with a canton pickup. The pickup was press fit with a bolt going through holding it on to the pump. I also welded the pickup on.
Browsing some threads, I saw someone mentioned an O ring between the pickup and the pump. I didn't look into the pump to see if there was an o ring, and I didn't install one. Does this come installed on the pump?
Also, is there a gasket that goes between the pump and the block?
THanks!
Old Apr 8, 2007 | 02:49 PM
MachinistOne's Avatar
No oring, no gasket.
Old Apr 8, 2007 | 05:57 PM
tim95z28's Avatar
Thanks!
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
