Oil pump
Old Dec 7, 2011 | 05:25 PM
97z28k&N's Avatar
Oil pump
Hello,
I'm wondering if my LT1 needs a new oil pump. My oil pressure gauge reads about 45 at cold idle, and 50 at cold driving. When at 180*, the idle pressure drops to about 15. Warm driving is about 40. My gauge doesn't bounce all around at idle so I believe my gauge is ok. My engine has about 140k on it.
Thoughts?
Old Dec 7, 2011 | 05:39 PM
Kevin Blown 95 TA's Avatar
Re: Oil pump
Sounds OK to me. What oil you using?
Old Dec 7, 2011 | 05:46 PM
97z28k&N's Avatar
Re: Oil pump
Mobil 1 (5w-30)?
The reason I question the '5W-30' Is because I had my dealer change the oil last time and I just told them to use the longest lasting mobil 1.
Old Dec 7, 2011 | 06:03 PM
Dave89IROC's Avatar
This readout off the stock gauge?
And yeah, sounds ok, but if worried, check with a mechanical gauge
Sent from my EVO 4G using Tapatalk
Old Dec 7, 2011 | 06:08 PM
97z28k&N's Avatar
Re: Oil pump
Yes I am reading the gauge from the dash.
Old Dec 7, 2011 | 06:12 PM
my1994z28's Avatar
Re: Oil pump
That pressure sounds pretty good,especially for having 140k on it..
Old Dec 7, 2011 | 06:29 PM
97z28k&N's Avatar
Re: Oil pump
nice
Old Dec 7, 2011 | 07:26 PM
RamAir95TA's Avatar
Re: Oil pump
The manual calls for 5w-30 - no problem there.
Old Dec 7, 2011 | 07:46 PM
97silverslpss's Avatar
Re: Oil pump
I thought that loss of oil pressure was caused by increased tolerances from bearing wear. It is my understanding that oil pumps rarely fail and cause a low oil pressure condition.
Maybe someone can clarify?
Old Dec 7, 2011 | 07:59 PM
97z28k&N's Avatar
Re: Oil pump
Also remember that the oil's viscosity raises as it becomes hotter
Old Dec 7, 2011 | 10:37 PM
Re: Oil pump
Viscosity drops as oil heats up. Its thick when its cold, thin when its hot.
From the Exxon/Mobil website:
Mobil 1 5W-30
SAE Grade 5W-30
Viscosity @ 100ºC, cSt (ASTM D445) 11.0
Viscosity, @ 40ºC, cSt (ASTM D445) 61.7
Old Dec 7, 2011 | 11:09 PM
Re: Oil pump
Presumed loss of oil pressure can come from an old sensor. They often indicate lower pressures as they age and as they get hot.
Old Dec 8, 2011 | 02:00 PM
97z28k&N's Avatar
Re: Oil pump
Sorry, that's what I meant
Old Dec 9, 2011 | 10:39 AM
raroz28's Avatar
Re: Oil pump
I often hear a lot of people talk about replacing pumps but being mechanical gear driven pumps I don't see how they can go bad so easily.
I spun a rod bearing so I disassembled the pump to clean out any shavings that may be in there, and replaced the nylon with a steel sleeve.
My oil pressure has been fine, although I will mention that my nylon sleeve was broken when I dropped the oil pan.
I've read that the sleeve breaking is common and can result in a slight loss of pressure but I am not sure how true that is.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
