Oil Pressure seems way too low...
Old May 3, 2013 | 03:07 AM
madmike_32's Avatar
I just replaced my oil pressure sending unit, as it was not working at all, and my gauge shows the pressure in the red at idle (about 750-800 RPM) once the car is warm. The car has about 106000 miles on it. When its cold the pressure is closer to 20 at idle, and when I'm driving normally the pressure is closer to 25-30 when the car is warmed up, a little higher when cold. I was wondering if there was something that would cause this? If i rev the car to just over 1000 RPM the pressure gets out of the red but is still at about 10 when warm. Any ideas/help would be appreciated.
Old May 3, 2013 | 05:33 AM
Re: Oil Pressure seems way too low...
The "Check Gauges" light should be on if the oil pressure is in the red. It comes on when the pressure drops below 6psi. That is the lower limit spec set by GM.
First, I would check the pressure with a mechanical pressure gauge, if you did not do so before replacing the old sensor.
Old May 3, 2013 | 10:09 PM
madmike_32's Avatar
The check gauges light does come on. After full warmed the gauge shows pretty much zero pressure. Once I give it gas it increases to about 15 at like 1200 RPMs. I'm gonna see about getting a manual gauge and checking it. Where would I hook it up to, since I've never used one before?
Old May 3, 2013 | 11:54 PM
slick1hunting's Avatar
there is a 1/4 plug right above oil filter to hook a manual guage too.
Posted from Camaroz28.com App for Android
Old May 4, 2013 | 12:20 PM
Courtesy of Shoebox:
http://shbox.com/1/aux_oil_port.jpg
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
