oil pressure question... please help
Old Jan 27, 2008 | 07:17 PM
glenb1991's Avatar
ok... when i start my car(94 Z28, true duals, and k&n CAI) the oil pressure rest at about... a little under 40.... once ive started driving... goin down the highway... at about 3k rpm... it goes all the way up to about... 60.... then when i come to a stop... it drops all the way down to a little less than 20... anybody know what could be wrong... how serious is it? thanks.
$Glen$
Old Jan 27, 2008 | 07:26 PM
hosspwr94's Avatar
oil pressure
from what I see in your sig you have around 150,000 miles on the car? It looks to me like your probably about due for a rebuild but your oil pressure is not as bad as it seems. as long as it kicks up to that 40-60 range while your driving its not bad. I know my last z was about the same as yours My current z has just had a rebuild and the oil pressure goes up to 65-70 driving and around 40 at idle.
$Glen$
Old Jan 27, 2008 | 08:43 PM
Pontiac_97's Avatar
sounds pretty normal to me. it should drop at ilde when hot. mine stays at 40 while cruising. hot summer day it will be around 15psi
Old Jan 27, 2008 | 09:02 PM
bombebomb's Avatar
Sounds normal to me.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
