Oil pressure guage pegged & temp guage inop!!!
Old Jun 9, 2005 | 10:33 PM
BTM's Avatar
BTM
Am just putting the finishing touches on the new engine/tranny transplant on my 95 Z (forged 355 / built 4L60E). First fireup went smooth w/ 2 exceptions:
1) Oil pressure guage is permanently pegged at top of range, way above 80 psi, regardless of ignition on/off, engine running/not, battery connected/not. Any advice? Please don't tell me I have to replace the whole damn cluster...
2) Temp guage doesn't work. Maybe I forgot to connect the harness to the sensor? Is it the one next to the spark plugs on the LH cylinder head?
Thanks guys
Old Jun 9, 2005 | 10:51 PM
OBE1 95Z28's Avatar
Re: Oil pressure guage pegged & temp guage inop!!!
Both issues sound like you didn't plug everything back in. The oil pressure sensor is on the top back of the block on the driver's side. Temp gauge plugs into the driver's side head between #1 and #3 spark plugs.
Old Jun 9, 2005 | 10:54 PM
madwolf's Avatar
Sounds like you either broke (most likely) or left the oil pressure sensor disconnected. It's on the back of the intake, connector towards the driver side. Very easy to break especially while doing an engine swap. It may be disconnected too. Same goes for the coolant sensor. Yes, the one that goes to the cluster is in the head.
Old Jun 9, 2005 | 10:57 PM
BTM's Avatar
BTM
BTW oil pressure sensor definitely is plugged in, and usually if not connected the guages will drop to zero, not max out.
Old Jun 9, 2005 | 10:59 PM
madwolf's Avatar
Mine maxed out when it was broken.
Old Jun 9, 2005 | 11:05 PM
turbo_Z's Avatar
A buddy of mine used a block out of a buick for his 355 build and it had a different oil pressure sensor.. slightly longer I believe. He experienced the same problem you are having so maybe you just have the wrong sensor!
Old Jun 9, 2005 | 11:08 PM
On a 4th gen, the oil pressure gauge will peg if there is no connection to the sensor.
Old Jun 9, 2005 | 11:11 PM
madwolf's Avatar
Another possibility is that you bent the pin inside the connector on the sensor. Take it out and look inside it.
HectorM52
Jul 30, 2017 11:46 AM
ad356
Apr 11, 2015 08:49 AM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
