Burnt spark plugs
Old Jun 9, 2005 | 11:19 PM
cb94ta's Avatar
Burnt spark plugs
Changed the spark plugs when I did my long tunes both sides were good and tan but the passenger side plugs were all burned pretty bad on the ceramic in between the boot and the plug nut(don't know what you would call it) what would cause that?
Old Jun 9, 2005 | 11:31 PM
OBE1 95Z28's Avatar
Re: Burnt spark plugs
Sounds like you had arcing between the plug boot and the head (ground). I'd use some dielectric grease on the plug boots or replace the wires if they are old. You can see arcing with the engine running in the dark.
Old Jun 9, 2005 | 11:43 PM
cb94ta's Avatar
I replaced the wires when I did the lt install I was just wondering if there was something I had to worry about. Why would all of the passenger side arc but none of the drivers side?
jayblev95
Jun 7, 2015 04:04 PM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
