oil pressure drop
Old May 4, 2006 | 02:30 PM
allblacksrt4's Avatar
oil pressure drop
when i come to a hard stop my oil pressure drops to zero. It has been doing this since i bought the car a year ago. i have changed oil pressure sender switch and the oil. the car has good pressure when driving and idle. when cold 60 and then when it warms up 40. when i accelerate it goes up. any idea's guys is my oil pump failing. or could it be a bad pick up in the pan?
Old May 4, 2006 | 03:04 PM
Re: oil pressure drop
That is often a sign that the pickup tube has fallen off the oil pump.
Old May 4, 2006 | 03:40 PM
so that would mean i would have to pull the pan to put it back on.. damn what a pain. how big of a problem is this. i plan on pulling the motor by the end of the year anyways.
Old May 5, 2006 | 11:31 AM
bump?
Old May 5, 2006 | 11:43 AM
bump?
Old May 5, 2006 | 02:33 PM
Please don't "bump" more than once in a 24-hour period.
You need to verify the loose pickup is your problem. First rule out a faulty sensor, wiring or gauge. Verify adequate oil level.
Old May 5, 2006 | 03:03 PM
jsetzer's Avatar
Drain the oil.
Give the pan a good tap, you should be able to hear anything large bouncing around inside.
Drop the pan. Its not bad, but if you have never done it set aside 2 days. Prob need to lower the kmember.
Old May 5, 2006 | 03:16 PM
sorry it was a double post okay thanks guys
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
