Well i just picked up.......
Old May 4, 2006 | 10:35 PM
crAzy95z28's Avatar
Places to put MSD 6AL, DIgital window switch, and Retard timing Box?
A msd 6Al ignition box, the 6000-6800 pills, and a Blaster coil all from MSD.
Now i need the MSD timing Retard box to plug into the MSD 6al. Where can i find this and the cheapest? I need this for the Nitrous!
Also should i get a harness or should i just wire it myself?
Randy
Old May 5, 2006 | 11:41 AM
crAzy95z28's Avatar
Re: Well i just picked up.......
Ok one thing. I dont want to wait to get the harness, im just going to go ahead and splice the wires on the coil.
Now on the coil, there is the Black terminal ( one wire)and the Grey terminal (two wires)
Do you know where the Orange wire, the Red wire, and the Black wire connect to on the coil from the MSD box?
Im not worried about the Big red wire or black one, just the little ones that connect to the coil. Anyone have a clue to which one each connects.
Also the coil wires are diff colors.
Randy
Old May 5, 2006 | 12:58 PM
crAzy95z28's Avatar
nvm im going to get harness!
Old May 5, 2006 | 01:00 PM
jamilz28's Avatar
what will an aftermarket ignition box do?
Old May 5, 2006 | 02:12 PM
2000GTP's Avatar
On a stock LT1 or a car with some simple bolt-ons, the aftermarket box will not do anything. In his case, he is running nitrous so the aftermarket box in combination with a few other things, he can retard the timing and spray in a certain RPM window.
Old May 5, 2006 | 02:44 PM
jsetzer's Avatar
Does this bypass/replace the ICM?
Old May 5, 2006 | 03:03 PM
ajschult's Avatar
I noticed better throttle response when I hooked my msd box up.
Old May 5, 2006 | 03:22 PM
crAzy95z28's Avatar
wow...hooking the wires up are easy, but i just spent the LAST 30 min trying to figure out where i want to hook up my Retard Box, and 6Al box. I also have a Digi WIndow switch box too....
I need help guys... Pics please or anyplaces where i can put the boxes?
Old May 5, 2006 | 03:55 PM
Dave89IROC's Avatar
nope
Formula Steve
Sep 19, 2023 08:31 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
1994formy
Wheels and Tires
Sep 28, 2015 01:11 PM
