oil pressure........
Old Sep 25, 2005 | 11:51 PM
cjiaf's Avatar
i was wondering about my oil pressure being low.....at an idel of 700 800 rpms my oil pressure is at the 20 mark somtimes a little higher it jsut depends.....i ask this casue i did pulleys and did not put the dampner on until like 6 months later and have ran it pretty hard with it off.....my buddy blew his motor that way and i am conserned i only have 57,000 miles on the car.....
Old Sep 25, 2005 | 11:59 PM
Re: oil pressure........
20+psi at idle is more than adequate. I lot of people with high mile engines would be glad to see that much pressure. I wouldn't be concerned.
Old Sep 26, 2005 | 12:02 AM
cjiaf's Avatar
ok cool....thanks thats alot off my chest.....
Old Sep 26, 2005 | 12:32 AM
Z95m6's Avatar
As Fred said 20psi isn't bad. I wouldn't worry about it.
Old Sep 26, 2005 | 04:12 AM
SS RRR's Avatar
Rule of thumb is 10psi per 1K rpm.
Old Sep 26, 2005 | 05:33 PM
r6bullets's Avatar
Yep you are fine, from my understanding GM says 6psi at idle is fine for LT1s. My engine however lost all oil pressure at a hot idle due to worn cam bearings. I have a new shortblock on the way. Engine had 109k on it, in a way it is good because now I will a have an engine with 0 miles on it.
Old Oct 5, 2005 | 03:23 PM
Black1995Z's Avatar
I have low oil pressure when the car is hot at idle, it sits just below the 1/4 mark. I would guess 4psi. Is this dangerous?
I just did a rebuild.
Durning normal driving and at startup the pressure looks good/normal
Old Oct 5, 2005 | 04:13 PM
Z95m6's Avatar
If you just did a rebuild your oil pressure should be 10x that much.
Old Oct 5, 2005 | 04:17 PM
mattybz28's Avatar
The 1/4 mark is 20psi so just below isn't 4psi. If 4psi is right, yes it's dangerous. If it's at 20psi it's still not very good if you just did a rebuild.
Old Oct 5, 2005 | 04:29 PM
Black1995Z's Avatar
what should I look for in fixing the issue?
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
