need some help - just finished heads/cam and problems
Old Oct 4, 2005 | 07:38 PM
97HUGGER's Avatar
I just finished doing a heads and cam swap on my 97 SS - have been driving it around for about 50miles and tonight decided to give it a full throttle run. Car had been running fine until after the full throttle run. Now when I come to a stop it wants to stall and the oil pressure gauge goes really low - if I rev the engine it comes back and while I am driving it is okay. I can hear the roller rockers ticking alot more than before. Engine temperature is fine. I upgraded to the 30# injectors and I am wondering if maybe the fuel pump is on its way out and if that is causing the stalling? I also re-used my vented opti-spark as it looked okay. It stalled on me twice but re-started right away - any help would be appreciated. Thanks.
Old Oct 4, 2005 | 08:16 PM
ajschult's Avatar
Re: need some help - just finished heads/cam and problems
Did you have it tuned?
Old Oct 4, 2005 | 08:25 PM
97HUGGER's Avatar
I have a mail order tune from PCMforless
Old Oct 4, 2005 | 08:40 PM
snakethis69's Avatar
i hate to ask this but did u install the tune? i was helping a guy that told me he had a tune but neglected to tellme he hadnt installed it yet! anyway i am also investigating a similar problem after my installs. i havnt loaded my tune yet but am hopeful it fixes it when the rest of my cable gets here. at warm i am idling at 500 rpm with 10PSI oil pressure. what about you?
Old Oct 4, 2005 | 08:47 PM
jchevy's Avatar
I have the same problem, usually starts after hundred miles or so of driving since the last tune. My buddies cammed car also does this. Do a search and you will see a lot of guys cars do this with no real way to fix it. I drilled out the IAC passage a little bit and it helped some, but it still comes back after a while. I just recently adjusted my IAC follower values, so far its been running good, but I dont have that many miles on it.
Old Oct 4, 2005 | 08:51 PM
97HUGGER's Avatar
I sent the computer away to be tuned so I know it is loaded in. It was idling at 10psi when it was wanting to stall but I just started it up now and the pressure is at 15psi idling and if I rev the engine it starts to go back up. I checked the oil level and it is okay and the motor seems quieter now. I wonder if I have a lifter problem or if the rockers just aren't adjusted correctly although I wouldn't think that would make it want to stall intermittently. I have an aftermarket 52mm t/b on and I am also wondering if that could be the source of the problem because if I held the gas and the brake at the same time I could keep it running but as soon as I let off on the gas it shut off. The engine rpm seems very high at idle also - it sounds okay but the tach is reading around 1200rpms.
Old Oct 4, 2005 | 09:15 PM
jchevy's Avatar
Your oil pressures are so low because your RPMs are so low and the car is about to stall. At 500 rpm it is probably barely just stumbling along.
Old Oct 4, 2005 | 09:29 PM
Z95m6's Avatar
I'd recommend doing that
Old Oct 4, 2005 | 09:34 PM
jchevy's Avatar
I just cant figure out why it comes back after a hundred miles or so.
Before i drilled it out, it did it all the time, after i drilled it out it just delayed it. I will get about a hundred miles after a new tune and then it will come back.
Old Oct 5, 2005 | 10:40 AM
how did u drill it out?
Old Oct 5, 2005 | 11:06 AM
Z95m6's Avatar
Probably with a drill and drill bit.
Old Oct 5, 2005 | 12:47 PM
Tekprodave's Avatar
It wouldn't hurt to upgrade the fuel pump and the change the fuel filter. It's always good to have a steady fuel pressure but it may not completely solve the issue. I had a surging problem that was solved with a new pump, filter, and pressure regulator.
Old Oct 5, 2005 | 04:12 PM
i got a new filter and a walboro pump but my problem still exists, maybe a new regulator is in order.
Old Oct 5, 2005 | 04:42 PM
Tekprodave's Avatar
I'm not confident that it will solve your problem but it wouldn't hurt to try. Another thing people often overlook is plug wires shorting on the headers. I popped the hood on a dark night and noticed quite a light show. Needless to say the car ran a lot better after I fixed that. LOL!!!
I'm not really sure what the issue is here I'm just trying to give you some things to try. As far as the low oil pressure goes, that is normal on the LT1's. Almost 0 PSI at idle.
Old Oct 5, 2005 | 05:27 PM
jchevy's Avatar
Put a scanner on the car and look at your IAC counts, this will tell you whats going on, if they are high, or maxed out, then your motor isnt getting enough air. You can try cracking the Throttle blades if you want instead of drilling out the IAC hole between the throttle blades.
And almost 0 PSI is not ok for a regular idle. If its idling low and barely stumbling along then i wouldnt worry about low oil pressure, but if you have a good idle and you have close to 0 pressure somethign is not right.
Victor Lamb
Aug 26, 2017 02:52 PM
Apr 3, 2015 10:54 AM
Collector Car
Jan 5, 2015 10:58 AM
F(ast)-body
Feb 26, 2003 09:05 AM
