Oil Pressure???
Old Jan 11, 2004 | 06:59 PM
skaterz28's Avatar
Oil Pressure???
what is my oil pressure supposed to run at?
when i first start my car (and its cold) it runs @ like 40psi
then after it gets hot @ idle it goes down to 22psi is this normal?
i have custom gauges so i dont know if its just the gauge?
Old Jan 11, 2004 | 07:01 PM
tanker's Avatar
its a bit low. Should be around 35 at idle worm, 50 cruising. Also depends on what oil you are using. Thicker oil reduces oil pressure
Old Jan 11, 2004 | 07:03 PM
skaterz28's Avatar
hey thanks for the info what oil should i use i have about 50000 miles on my car
Old Jan 11, 2004 | 07:10 PM
tanker's Avatar
I use for winter time- 5w30, summer- 10w30 semi syntetic oil. 50k miles is not much for LT1. This is my way, everyone has their own way taking care of engine.
Old Jan 11, 2004 | 07:42 PM
RCF925's Avatar
skaterz28, Your oil pressure is normal, Don't worry about it. I've had 4 Z28's and the pressure is where yours is on a stock motor
Old Jan 11, 2004 | 07:47 PM
Tony Danza's Avatar
I dont see how thats true. Maybe a typo?
Old Jan 11, 2004 | 07:51 PM
MEAN LT1's Avatar
Yea...thats wrong, thicker oil will increase oil pressure not the other way around.
Old Jan 11, 2004 | 11:40 PM
S.J.S.'s Avatar
Hey Skater.....that is totally normal. WHen you say 40 psi cold and 22 warm, I'm assuming your talking about being at idle.
Old Jan 12, 2004 | 11:18 AM
skaterz28's Avatar
yeah thats @ idle it goes up some when i start driving
hey thank guys for all the info i was kinda worried about it
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
