Which Oil Pan for stroker?
Old Jul 16, 2006 | 12:33 PM
AmTrans's Avatar
I have searched these forums with several key words but came up with no luck.
I looked at summit and they have like the moroso oil pan but it says it is not stroker clearanced.
What oil pan / pickup / windage tray combo are people using with 383's these days? I know there is a canton one somewhere, any idea of the part #?
Any advice would be greatly appreciated!!
Old Jul 16, 2006 | 12:51 PM
1racerdude's Avatar
Re: Which Oil Pan for stroker?
The Canton is a 242T. It is a road race pan and ya can find it in that section of their site.
Old Jul 16, 2006 | 01:30 PM
NVetro's Avatar
Yep, its the one I used for my stroker build.
Old Jul 16, 2006 | 02:42 PM
Stock pan works fine for a 383.
Old Jul 16, 2006 | 02:52 PM
NVetro's Avatar
Injuneer is right, you can use it, but you mite have to "mod" the bottom of the pan for clearence in most cases. Some people take a rubber malet and just bang the bottom of it out. I splurged the $250 for a nice new pan
Old Jul 16, 2006 | 04:12 PM
The Engineer's Avatar
Moroso has a "new" LT F-Body pan. I got one of the first ones made (around June 1) thru Jeg's and initially it clears the crank on my Golen 396. It looks to be a quality product. Also, I'm using the Moroso HV oil pump and pickup.
http://www.cardomain.com/ride/2189634
Old Jul 16, 2006 | 05:37 PM
AmTrans's Avatar
Wow didn't know I could use the stocker...
Now that I think of it, I think I read that here somewhere but don't you have to remove thewindage trey or something? I also read here that no windage trey creates drag on the crank from the oil?
Sorry I don't mean to have you guys repeat things that may have already been said, just trying to clear things up a bit.
Old Jul 16, 2006 | 05:48 PM
1racerdude's Avatar
If I had spent the money for a stroker I damn sure wouldn't put a stock oil pan on it that leads to ALL kind of other problems if not modified.
Like oil climbing the back of the pan on launch and going to 0 psi OP.
Old Jul 16, 2006 | 07:19 PM
AmTrans's Avatar
Really?
I definitly don't want to run into any problems. I would rather spend the money than worry.
Does anyone else have any suggestions on what he mentioned?
Old Jul 16, 2006 | 07:22 PM
1racerdude's Avatar
Do a board search on OP/oil pan problems. That should keep ya reading for a while.
Old Jul 16, 2006 | 08:06 PM
I must be the only person around with the new Moroso LT F-Body oil pan (call Moroso, it isn't in the catalogs yet). It is a really neat set-up. Built-in windage screen/tray, baffles, increased capacity. I can't believe no one is using it, or recommending it! Also, I used their HV oil pump w/ matching pickup tube for that pan.
Old Jul 16, 2006 | 08:09 PM
97s10ondubs's Avatar
I used the canton pan for mine, but the crank was hitting the crank scrapper, so I had to hit it in a few places, turn it over by hand w/ the pan on so you know if yours will clear or not.
Old Jul 16, 2006 | 11:47 PM
T/A KID's Avatar
I bought a Milidon from VRE along with there pick up and pump. Looks like a nice kit from what I seen. Nick at VRE uses the Moroso and the milidon pans
Old Jul 17, 2006 | 07:51 AM
You should have told George Baxter that before he built his 1,125HP LT1, using the stock pan and the stock oil pump. No problem with 1.3-sec 60-ft launches, wheels 4 feet in the air. It does work, if done correctly.
http://www.injuneer.com/images/photo.../fGeorgeWS.jpg
Old Jul 17, 2006 | 08:24 AM
rskrause's Avatar
Moderator
Stock pan and pump works good and you already have it. Stock pan and HV pump - don't go there.
Rich
