Which Oil Pan for stroker?
Old Jul 17, 2006 | 08:59 AM
  #16
Javier97Z28's Avatar
Moderator
Re: Which Oil Pan for stroker?
I'm happy with my Milodon 30909... sure looks good too
Old Jul 17, 2006 | 09:20 AM
  #17
SevenStars's Avatar
Question: What else is needed to run the Milodon pan? Can I re-use the stock dipstick and a stock replacement gasket?
Old Jul 17, 2006 | 10:11 AM
  #18
JustNO's Avatar
Canton is a great oilpan, but with long tube headers you should cancel the "low oil sensor" ..
My Kooks Lts (actually the left one) touch the stud that I replace for "low oil sensor".
Old Jul 17, 2006 | 11:04 AM
  #19
Gripenfelter's Avatar
Stock pan is fine for a stock oil pump.
I put a high volume one into a stock pan and it sucked it dry at the top of 3rd whenver I did a burnout first.
Old Jul 17, 2006 | 12:03 PM
  #20
Moderator
Yes, and yes.
Stock dipstick tube needs to be cut at the bottom to fit... OR.... you can shave down the inside of the pan.. I opted for cutting the dipstick tube. As far as level goes.. I know my car takes 5.5 quarts.. so I just go by that...
You lose the oil level sensor, and you need to do some trimming of the factory braces... I had to grind down the edge a bit to fit the knock sensor. No biggie.
Old Jul 17, 2006 | 02:12 PM
  #21
1racerdude's Avatar
Originally Posted by Injuneer
You should have told George Baxter that before he built his 1,125HP LT1, using the stock pan and the stock oil pump. No problem with 1.3-sec 60-ft launches, wheels 4 feet in the air. It does work, if done correctly.
http://www.injuneer.com/images/photo.../fGeorgeWS.jpg
Was it completely STOCK on the inside???
Old Jul 17, 2006 | 03:12 PM
  #22
Severous01's Avatar
383, stock pan, stock replacement pump. chevy designed anawesome pump for the small block. i watched a build on a 650hp monster rat and they actually suggested not going with a hv pump or aftermarket pan unless you just wanted it to look good...which they did because it's tv. but they still used a stock oil pump.
Old Jul 17, 2006 | 03:20 PM
  #23
The pan was stock, the windage tray was not. I have the same setup.
Old Jul 17, 2006 | 05:08 PM
  #24
stew's94z's Avatar
I'm also running a stock pan with a louvered Milidon windage tray. The pump is a More performance blueprinted standard volume with the white spring.
It works for me too.
Dean
Old Jul 17, 2006 | 05:22 PM
  #25
arcticz28the383's Avatar
If your going to use the stock pan, make sure you find some way to use a windage tray. If you don't, you will lose oil pressure when you launch the thing.
IMO, why would you keep the stocker for an expensive motor? It needs to be clearenced with a hammer (not just the bottom but the rail too), it holds less oil, and aftermarket pans come with better windage trays/crank scrappers anyway.
my 2 cents.
Old Jul 17, 2006 | 06:32 PM
  #26
1racerdude's Avatar
my 2 cents.
My thoughts exactly.
Old Jul 17, 2006 | 10:24 PM
  #27
my 2 cents.
Because it works fine. Why spend money on something that isn't needed. You can not argue with 1,000+HP engines using stock pans..... if they didn't work, the engines wouldn't be lasting long and healthy lives.
Old Jul 17, 2006 | 10:48 PM
  #28
AmTrans's Avatar
You guys have been very helpful so far.
Last question then!
What windage trey are you using with the stock pan? Will it bolt right in?
I guess I should sell my HV pump and get a regular one?
PS that was more than one question, oh well!
Old Jul 18, 2006 | 06:25 AM
  #29
GetaZforgetGT's Avatar
If your interested in running the stock pan do a search on Milodon double diamond windage tray.
The below thread covers a lot.
http://web.camaross.com/forums/showt...n+windage+tray
Old Apr 21, 2007 | 04:32 PM
  #30
96LT1TX's Avatar
this same argument has made me very angry lately also. On my post no one wanted to say the stock pan was useable, and if they did say it was, they wouldnt say how. I have stock pump, pan, no windage tray. I am about to weld in some baffles in the oil pan, but if anyone can give me some direction (besides looking at the canton and going off that) that would be great. I know you guys think 383s are expensive and all, but my heads/cam 383 cost about 3000$ and another 300$ just isnt in the books.
I am about to put in a OEM windage tray and see the clearance issues with the big crank... with the windage tray/baffles welded in, anyone have any advice on where/how?
PST-Injuneer/rskrause...
