oil pan gasket
Old Apr 18, 2008 | 12:03 AM
lt1loudmouth07
Guest
Posts: n/a
oil pan gasket
Do i have to take my timing chain cover off to replace my oil pan gasket
Old Apr 18, 2008 | 01:22 AM
Ratlor's Avatar
That's sort of a yes and no. Would it be better to do? In my opinion, yes. Do you have to? Probably not.
The bottom of the timing cover gets sealed by the front of the oil pan cover, so it is possible to mess up the bottom of the gasket. Plus it's always good to change the timing chain cover gasket as sort of preventative maintenance.
Old Apr 18, 2008 | 05:58 AM
M93Z's Avatar
No!
Old Apr 18, 2008 | 06:51 AM
Pontiac_97's Avatar
NO. You will be fine without taking it off
Old Apr 18, 2008 | 06:54 AM
mzgp5x's Avatar
No I did not remove the time_chain cover (1997ss LT1). I did have to lift the engine up off the front mounts. Engine lift was about 1 1/2+ inch. I have an aftermarket pan, so, I could not remove it (due to K_member low clearance). Slipped the new oil pan gasket around the front and rear to set it in place. B.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
