AIR delete
Old Apr 17, 2008 | 08:11 PM
MTBSully's Avatar
AIR delete
My race headers just showed up and i just bought EGR block-off plates but how do i delete the AIR system from my car? Any tips or other links are helpful. Thanks
Old Apr 17, 2008 | 08:59 PM
Crows89RS's Avatar
i just unplugged the AIR pump, took it out, and proceeded to throw it at my driveway, since it was blown. then put a good fuse in the fuse box for the AIR pump, and never had any problems. i think there's a vacuum line going to it or something, I don't remember, thinking it went into the drivers side manifold? never have had any SES codes for hte AIR pump though (except from before i took it out when it was blown).
Old Apr 17, 2008 | 09:13 PM
jclark311's Avatar
There is a vacuum line that goes to the drivers side intake manifold, that needs to come off, and plug the intake.
Old Apr 18, 2008 | 07:33 AM
Whether there is a vacuum line (and several other components) depends on the year of the car, and whether the "AIR recall" was done on the car.
Courtesy of Shoebox:
http://shbox.com/1/air_pump_recall.jpg
When you delete the AIR pump, you will remove the air supply line that runs from your air intake ducting to the AIR pump. The connection on the air ducting needs to be blocked off with a 3/4" vacuum cap.
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
armedtrigger
Feb 24, 2015 08:30 PM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
