oil in opti
Old Jun 4, 2008 | 07:33 PM
ARZ28's Avatar
oil in opti
i took my opti of my 1994 z28 and it seem to have oil on it and maybee in it.i dont have the little socket to take it apart yet,but can that happen to these things and does that mean the whole thing is shot?what is the cheapest way to go to fix these or replace them and stiil have some dependablity.thanks for any info
Old Jun 4, 2008 | 07:37 PM
If it has never been changed, it's time. A genuine GM opti is probably the best value at this time.
Old Jun 4, 2008 | 08:57 PM
ARZ28's Avatar
where is the best place to get a gm opti?have you ever heard of a cardone opti?from advanced auto with a lifetime warranty and are they any good
Old Jun 4, 2008 | 09:05 PM
DAVE00's Avatar
If you have oil in your opti, I would tend to believe you have a leaking WP or Opti seal in your timing cover. This is not uncommon and while you have your opti off I would check them and probably go ahead and replace them. Very easy and do a seach as tons of info will turn up.
Old Jun 4, 2008 | 09:08 PM
ARZ28's Avatar
what is a wp seal and where is it and where is theopti seal
Old Jun 4, 2008 | 09:16 PM
DAVE00's Avatar
The WP (Waterpump) seal and Opti seals are two circlular seals in the timing cover. One is located directly behind the WP and the other is directly behind the Opti and they seal the timing cover to both. See the diagram below and look at the two circular holes in the upper portion of the timing cover. Top one is WP and middle one is for opti.
Courtesy of Shbox's website:
Old Jun 4, 2008 | 10:00 PM
ARZ28's Avatar
thanks for the diagram.can i change those without taking the timing cover off?thanks
Old Jun 4, 2008 | 10:41 PM
GM/AC-Delco/Delphi, they are the same thing. I don't recommend any others. thepartsladi on Ebay seems to be a fair price. Beware of others on Ebay. There is a GM parts contact listed on my Tech Page.
That drawing looks better in its non-condensed, original form...http://shbox.com/1/engine_front_diagram.jpg
Old Jun 4, 2008 | 10:53 PM
ARZ28's Avatar
do i have to take the timingcover off to change the seals
Old Jun 4, 2008 | 11:03 PM
No, you don't.
Old Jun 5, 2008 | 08:18 AM
Pontiac_97's Avatar
you can pick up a new ac-delco opti from summit racing for like $310 bucks. they ship very fast
Old Jun 5, 2008 | 11:26 AM
Warren_Seale's Avatar
You can also check with these AC/Delco dealers:
www.oehq.com
www.autopartsgiant.com
They have very low prices on all AC/Delco parts.
Warren
Old Jun 6, 2008 | 02:19 PM
ARZ28's Avatar
thanks for the help i have a new opti coming from the partsladi and a opti seal and wp seal coming from nook and trany on ebay.cant wait to here this car run i have put some much money and time in it.thanks again everyone.
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
ad356
Apr 11, 2015 08:49 AM
grabbem88
Mar 18, 2015 01:25 PM
