oiL light
oiL light
I just did a full tun up to mu 95 camaro z28 but for come reason I noticed the oil light turns on checked the oil level evrything looks good but stii the lights turns on and on from time to time has anyone expeeriance this beforlet me know any suggestions
Re: oiL light
95's don't have an oil life computer and, thus, no 'change oil' ight. All they have are 'check gauges" and "low oil" lights. I assume he means the "low oil" light as any oil pressure warning would be handled by the 'check gauges' light.
If the oil level is OK when checked with the dip stick, then the sensor is bad. The thing is made from plastic and lives in a tough environment.
Be careful when replacing it. Over-torquing it will break it. Not might, will. Replace the seal while you're in there.....
Jul 4, 2005 05:00 PM
