oil leaks. what is most likely????
Old Feb 19, 2018 | 10:02 AM
  #16
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Re: oil leaks. what is most likely????
Off topic, but are those OEM C6 wheels, or aftermarket?
Old Feb 19, 2018 | 10:07 AM
  #17
Chimera96's Avatar
Originally Posted by wideglide2011
I have replaced the oil pan gasket ,timing cover gasket and seals.now on to the intake
any good tips to seal the intake??
Use the FelPro "printo" series intake gasket. They have the blue sealing bead around the intake ports
Permatex Black "ultra" RTV on the front & rear china walls and run it up about 1/2" onto the side intake gaskets
Make sure you drop the intake back on dead nuts on the motor. You don't want to have to "slide" it into position once dropped as it will push RTV off. Some people use short pieces of wood dowel on the front & rear bolt hole on one side of the engine to guide the intake on. Leaning over car placing the intake on exactly can be awkward. Try a few dry runs before putting on RTV or use dowels or something like them to assist in alignment if you want. I don't but some do.
Don't start motor until next day so RTV can cure after install. There is a TQ sequence for intake bolts. Basically starting center working out in cris cross pattern
when removing intake bolts use a piece of cardboard with holes punched in mimicking the order they are removed as some are different heights (studs) so you can put them back in order. Vacuum intake so debris does not fall into motor when you pop intake off. There is a pry point PS front of intake for removal
Haynes service book or FSM will have step by step procedure
Old Feb 20, 2018 | 05:14 PM
  #18
wideglide2011's Avatar
thanks for the tips on the intake install.does the felpro gasket make a big difference?? I already purchased another brand from summit is why I asked..
Old Feb 21, 2018 | 10:49 AM
  #19
Chimera96's Avatar
The printo seal line of FelPro does seal better than standard gaskets. With that said the stock intake gaskets don't have this feature and for me were not a problem when my motor was stock
Summit is good about return or exchanges if you want to change to the printo type from FelPro
Donohue96M6Z28
Feb 17, 2006 04:24 PM
Don't Look Back
Sep 9, 2004 06:19 PM
raxxus
Feb 24, 2004 11:31 PM
TMDZ28
N2O Tech
Jul 20, 2003 11:21 PM
