Oil leak from intake
Old Jun 23, 2007 | 10:53 AM
Krusty's Avatar
I am new to the site having just purchased a 95 z - lt1 6speed & have an oil leak fron the intake. I was wondering since I am new to the whole lt1/z28 scene if I could have some feed back as to what other recommendations you all may have while I have the intake off. The car is compltely stock at this time & I plan to use it as a daily driver/toy in the summer. Was planning to put a cold air intake & some exhaust mods as well as "chipping" but there seems to be a ton of options out there so I thought this would be the place to start.
Thanks in advance for any advice.
Old Jun 23, 2007 | 10:58 AM
2nd_chances's Avatar
Just fix the oil leak.
You have nothing to gain by messing with the intake on a stock motor.
Old Jun 23, 2007 | 11:17 AM
Ironxcross's Avatar
I need to get around to fixing mine - I haven't yet and it has leaked since probably the day it left the factory. It's leaked since I've had it for sure (6 years / 45k miles) and getting under the car to work on it is getting annoying when you're filthy afterwards.
you dont need to go under the car to fix it. atleast i didnt have to. supposedly theres an egr pipe on the passenger side that heats up the back of the intake manifold where its just held on by sealant. eventually it melts the sealant and the pressure inside the engine bursts through and causes a leak. i fixed mine with header wrap for the egr pipe and high temp. sealant for the intake manifold. works like a charm now.
Old Jun 23, 2007 | 11:32 AM
2000GTP's Avatar
It would be a good time to do a throttle body bypass mod, which is a free mod. Other then that, there is not much else to do.
Magenta_Hearts
Mar 29, 2017 08:54 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
Dr. Weir
Aug 2, 2002 02:36 AM
