Can I fire up without sensors plugged in?
Old Jun 23, 2007 | 10:18 AM
scottso's Avatar
I just put in my new opti - don't have the water pump installed yet and I want to fire up and make sure I run OK. Do I have to reconnect the MAF, IAT, etc, etc? Or will she start and run without all of that stuff connected?
Old Jun 23, 2007 | 11:09 AM
Dave89IROC's Avatar
go ahead, may crank slightly longer without a MAF, but as long as the opti, coil, plug wires, TPS, IAC, MAP and injectors are hooked up, it will start
Old Jun 23, 2007 | 11:43 AM
At least connect the harness to the coolant temp sensor, even if its not installed in the water pump. If it is left unconnected, the PCM will interpret it as -40*F and set an extremley rich cold start mixture. You can do the same thing with the IAT sensor. Just plug it into the harness. IAT doesn't have that much affect one way or the other, though.
Drtryder
Apr 22, 2015 04:17 PM
3TAS4ME
Apr 15, 2015 02:24 PM
grabbem88
Mar 18, 2015 01:25 PM
Jazsun
Dec 29, 2014 12:14 PM
