Oil Guage wiring question???
Old Jul 11, 2006 | 10:21 AM
BLDun's Avatar
I am installing a separate oil pressure guage and have a question. Can I simply tap into the wire that now comes from the oil pressure sensor or am I going to have to add a separate pressure sensor for this guage???
Old Jul 11, 2006 | 10:33 AM
Re: Oil Guage wiring question???
I would say you need a separate sensor. Tapping into the existing one will likely throw off the resistance reading and make both gauges inaccurate.
Old Jul 11, 2006 | 11:27 AM
BLDun's Avatar
Shoebox, I am having trouble finding the auxiliary oil port. I looked at your pic but it is too close to see exactly what's around it. I see the edge of the oil filter but on my engine I can't find the port. Is it located on the side of the block or at the back?? Either way I'm probably going to find I don't have much room to screw in a sending unit.
Old Jul 11, 2006 | 02:17 PM
Its on the side, right above the oil filter. I use that port for my mechanical oil pressure gauge.
Look at the pipe plug stuck in the block above the filter/oil cooler.
http://members.aol.com/InjuneerZZ/im...hotos/Dyno.jpg
Old Jul 11, 2006 | 03:51 PM
BLDun's Avatar
Thanks, Fred, I finally found it. Problem is that the sending unit I have doesn't match hole. It has fine thread and looks to be about 3/8 while the plug I pulled out has a coarse thread and appears to be be 1/4". Any ideas where I can pick up a sending unit??
Old Jul 11, 2006 | 04:42 PM
Just get some adapter fittings.
Old Jul 11, 2006 | 04:51 PM
You have an electric pressure sender? Are you sure its 3/8"? Usually they are 1/8" NPT (which has an O.D. of about 3/8"). The hole in the block is 1/4" NPT. There's a 1/8 x 1/4" NPT bushing that would reduce the hole to match the sender.
You may also need an elbow to point the sender in a different direction, because space is at a premium at that location. I have a mechanical oil pressure gauge, and a brass elbow screwed into the block, with a -4AN braided hose running into the dash.
You can see the elbow in this pic, and how crowded it is:
http://www.injuneer.com/images/photo...e/DCP03020.jpg
Jul 4, 2005 05:00 PM
CobraEatr
Jul 24, 2004 11:37 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Lions3
Aug 6, 2002 05:33 PM
Zomie
Jul 21, 2002 08:03 PM
