Oil filler tube
Old Dec 1, 2018 | 02:02 PM
KYWes's Avatar
Oil filler tube
1995 Z28
My oil filler tube won't stay tight and I'd like a new o-ring for it. Does anyone know what o-ring it is? I can find one online for the 3.8 filler cap but don't know if it's the same one. Also what has anyone done about the loose filler neck? Mine is leaking and it's making a mess.
Old Mar 1, 2022 | 08:42 AM
squarehead's Avatar
Re: Oil filler tube
Kywes, Did you ever get a part number for the O-ring on the filler neck?
Old Mar 4, 2022 | 01:30 AM
KYWes's Avatar
Re: Oil filler tube
Nope, never did find out what the part is for sure. I'd still like to know.
Old Mar 9, 2022 | 06:00 PM
squarehead's Avatar
Re: Oil filler tube
Hi KYWes, I had luck with the O-ring for the filler neck to valve cover connection but not the cap to filler neck though I think they should be the same O-ring. I bought some generic metric size O-rings from my NAPA auto parts store that were listed for fitting 30 mm fittings. The actual rubber ring is slightly smaller than 30 mm on inside dimension and about 3 mm thick. I was able to get it onto the filler neck O-ring slot no problem and with a little silicone oil got the neck to screw all the way down to the valve cover top surface. When I tried using the same O-ring for the cap I could not get the cap to seat all the way into the filler neck recess like the original O-rings do.
edman
Jun 23, 2007 08:05 PM
theroad64
Parts Wanted
Mar 22, 2006 03:56 PM
sabre81
Mar 27, 2004 05:42 PM
Draco
Mar 22, 2003 11:48 AM
