Oil dipstick routing after headers
Old Dec 2, 2006 | 02:58 PM
chevroletfreak's Avatar
Does anyone have a picture of how they routed their dipstick after installing headers? I just put in Edelbrock headers and cant get it routed neatly. Also, is there any aftermarket dipsticks that will work better?
Old Dec 2, 2006 | 03:52 PM
1FstFormulaV8's Avatar
You could oh so carefully bend the tube for fitment. You're taking a big chance though, if you begin bending and it crimps. You're done for.
Old Dec 2, 2006 | 03:54 PM
Thats what I tried to do, but I am having problems getting it bent correctly and then getting it back into the block. The Edelbrocks are pretty tight to the block. Did you run yours on the outside of the header or closer to the block?
Old Dec 2, 2006 | 04:01 PM
I don't have a set of TES headers. I have Pacesetter LT's just sitting in the box. I'm waiting for my true duals.
Old Dec 2, 2006 | 04:15 PM
joeSS97's Avatar
You should be able to get it in there...If not Lokar makes one,available at Jegs or Summit.
Old Dec 2, 2006 | 04:47 PM
Thanks, I was able to find it on Summit, but I don't see an LT1 model available. Do you have the correct part # by chance?
I would still appreciate picks if you have any to try and use the one I have. That can prevent me from waiting another month for it to get here from the states.
Old Dec 2, 2006 | 04:59 PM
SevenStars's Avatar
Well its all I got but it might give ya an idea.. its how I routed my dipstick with my SLP Headers, I figure something is better than nothing...
Old Dec 2, 2006 | 05:02 PM
Cool thanks. I will have to check tomorrow. I may have mine routed uner all four pipes. It is a pain to get that thing out again since it is in the car.
Old Dec 2, 2006 | 06:09 PM
TobyZ28's Avatar
getting it in the block = Use a fine grit sandpaper to sand down the end. It'll go in MUCH easier
Old Dec 2, 2006 | 08:56 PM
wrd1972's Avatar
Better put some gray RTV on it or it will leak.
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
jmadoll
Mar 3, 2015 10:16 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
