Dot to dot no pressure out of #1???
??? I've put quite a few big and small blocks together and my first LT1 stumped me... So i pull the cover and spin the motor and i get pressure out of #1 get up and look and WTF both marks are up...IM NOT A RETARD... ok exhaust pressure fooled me so i do it again... pressure and i look, both marks up, not dot to dot????????????What is going on with this thing??? How did my motor run???
Re: Dot to dot no pressure out of #1???
Originally Posted by anaik
With the LT1 when the dots are 6 and 12, the opti is firing #6 cylinder. When 12 and 12, number 1 is getting the juice.
It's not only the LT1,most all engines are like that that have a chain and two sprockets.
You tell me.
If they are 12-12 that's OK if they are 6-12 that's OK too.
What way was the rotor pointing. Ya can put the dist in and the wires in any order of rotation, but if ya knew which way the rotor points when it's on #1 and ya put it in on six then it would be 180 out.12-12 is #1 and the rotor is pointed to the back of the carb on the passengers side corner.
14
Aug 11, 2015 12:03 PM
