Oil dipstick bolt
Old Sep 2, 2008 | 06:23 PM
kyleg001's Avatar
Red face Oil dipstick bolt
Does anyone have a pic of where the oil dipstick bolt conencts to the motor?(94 camaro)
Does anyone know the bolt size/length this is?(3/8 16)
I've got everything put back in and forgot to hook up the dang dipstick tube, now I cant seem to find where it should be connected.
Old Sep 2, 2008 | 06:27 PM
LaredoZ28's Avatar
the bolt is metric. I'll see if i have one lying around real quick to get the size and i'll snap a pic of where it goes.
Old Sep 2, 2008 | 06:39 PM
LaredoZ28's Avatar
The bolt is an M6 bolt that is aprox. 3/8's of an inch long. It has a 10MM head. it screws in above the starter. i'm uploading a pic to give u an idea.
Old Sep 2, 2008 | 07:28 PM
FlamingChicken's Avatar
funny thing is i logged on here to ask the same question. the pic would be very helpful.
Old Sep 2, 2008 | 07:34 PM
LaredoZ28's Avatar
Here is the pic of where the oil dipstick bolt goes. You will c in the pic that i'm pointing to where it should go.
Old Sep 2, 2008 | 10:22 PM
The bolt is definitely not metric. It should be a 1/4-20 x .56 and probably a 3/8 head.
I have never found any metric bolt that threads into the LT1 block.
All you have to do is put the dipstick in and see where the hole in the mounting tab lines up. Your bolt hole should be close by.
Old Sep 2, 2008 | 10:28 PM
LaredoZ28's Avatar
Ur right. I'm used to all the metric bolts on the tranny's and the hedders.
The pic should help them figure out where the tube bolts to. the motor is out of my car though. I hope it helps.
Old Sep 3, 2008 | 12:10 AM
kyleg001's Avatar
Smile
LaredoZ28: Thanks for the picture
I was asking this question because I believe my dipstick tub and bracket are a little tweaked and wasn't sure/couldn't see where it should be mounted to. I have almost no visibility to the left side of my motor due to my headers.
Old Sep 3, 2008 | 09:28 PM
LaredoZ28's Avatar
No Problem bro. I just happened to have a motor on the stand when i saw ur question so i snapped a pic while i had the chance.
Old May 9, 2011 | 12:24 PM
96LT1TX's Avatar
Re: Oil dipstick bolt
shoebox saves me again. When I need to find something intricate (size and thread count of the dipstick tube mounting bolt) I literally search for shoebox and search in those for my subject! thanks again man.
Old May 9, 2011 | 03:57 PM
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
