Oil all around intake gasket!
Old Apr 13, 2004 | 06:07 AM
  #16
2Fast94TA's Avatar
i just just had the emissions done last year, and they only put it on the dyno roller things, but my dad just did his 97 blazer and they only did a computer scan, i think its a obd2 thing only
Old Apr 13, 2004 | 08:30 PM
  #17
2Fast94TA's Avatar
alright i got tearing into it, and the entire pcv valve system seems to be covered in oil, under the TB plate has a coating of oil. also my antifreeze had some oil in it, is that just a sign that the intake gasket was blown out?
Old Apr 14, 2004 | 06:04 AM
  #18
2Fast94TA's Avatar
anybody know, could a leaky intake gasket cause oil in my antifreeze?
Old Apr 14, 2004 | 08:30 AM
  #19
sabre81's Avatar
sounds like you had increased crankcase pressure. maybe pushed some oil into the cooling sys. i would make sure your pcv valve us functioning, and if not replace it. also buy one of these guys from autozone It stops oil from going into the tb.
Old Apr 14, 2004 | 09:28 AM
  #20
2Fast94TA's Avatar
well the pcv valve and TB was coated in oil, your link does not work but im guessing its the cirlce shaped breather you put on your pass. side valve cover
Old Apr 14, 2004 | 10:22 AM
  #21
sabre81's Avatar
correct http://collop.cz28.com/custom2.html
Old Apr 14, 2004 | 06:02 PM
  #22
cndctrdj's Avatar
i actually think i have this same problem .... i will have to take picutres of it and see if you guys can tell me what it is
Old Apr 14, 2004 | 09:29 PM
  #23
2Fast94TA's Avatar
still i dont have a clue on how oil could of gotten into my antifreeze, its usally the other way around. could someone please enlighten me?
Old Apr 15, 2004 | 01:38 PM
  #24
blown383's Avatar
Oil in your antifreeze? Check your oil...if it looks milky dude......you blew a head gasket.
Old Apr 15, 2004 | 09:10 PM
  #25
2Fast94TA's Avatar
yea i must of been on crack but i thought i saw a small amount of oil on the termostat, i just drained the oil and it was the regular brown color. i did get my intake gasket in today and well see if it works. i did have to giggle it a little to get some of the bolts to line up, hope that didnt break the seal.
Old Apr 21, 2004 | 12:50 AM
  #26
Lower's Avatar
Originally posted by FlyBono24
Does anyone have updated links to the intake manifold fix? All the links on that site are broken.
Psst! Scroll down.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 27, 2014 09:41 AM
97 RedSS
Jun 10, 2003 07:58 PM
