Oil all around intake gasket!
alright i got tearing into it, and the entire pcv valve system seems to be covered in oil, under the TB plate has a coating of oil. also my antifreeze had some oil in it, is that just a sign that the intake gasket was blown out?
sounds like you had increased crankcase pressure. maybe pushed some oil into the cooling sys. i would make sure your pcv valve us functioning, and if not replace it. also buy one of these guys from autozone It stops oil from going into the tb.
yea i must of been on crack but i thought i saw a small amount of oil on the termostat, i just drained the oil and it was the regular brown color. i did get my intake gasket in today and well see if it works. i did have to giggle it a little to get some of the bolts to line up, hope that didnt break the seal.
