Ohm value of temp sending unit 95 LT1
Old Aug 13, 2015 | 03:26 PM
4586's Avatar
Have the 95 LT1 driveline in a street rod and using a Marshall aftermarket dash cluster that uses it's own temp sending unit (which is not super accurate).
What I would like to do is use the OEM temp sending unit feed wire intended for the 95 cluster and install an auxiliary digital temp gauge.
Anyone know the correct ohm range required for an aftermarket temp gauge display to work with the factory 95 LT1 temperature-sending unit?
Old Aug 13, 2015 | 04:08 PM
DelSoto's Avatar
Re: Ohm value of temp sending unit 95 LT1
Courtesy of Shoebox: 4th Gen LT1 F-body Tech Articles
Old Aug 13, 2015 | 04:21 PM
The Marshall FAQ has some info:
Frequently Asked Questions
See if this matches the standard GM ohms vs. temp.
Old Aug 13, 2015 | 10:11 PM
4586's Avatar
Fred
By comparing those values last week we learned that the display was off about 12-15 degrees from actual warmed up temperature. I compared the temperature on my OTC Nemisys datalog and the Marshall gauge also.
My son is contacting Marshall to see if they might have better tuned sending unit.
Thanks..
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
slothgrant
Aug 22, 2002 03:01 PM
Omega9
Aug 2, 2002 12:33 AM
