OEM Lifters...what's the difference?
Is there any difference between lets say Comp OEM lifters, OEM lifters you would buy from GMPP or the ones from any local auto parts store? Just tossing this out there because I did a search on OEM lifters and was just curious. Thanks
Re: OEM Lifters...what's the difference?
That's what I figured. I usually spend time researching aftermarket parts not OEM stuff. I had Comp R's for a while but I had three of the retainer rings break over a two month period. That's the reason why I was looking at the different OEM lifters. I Would like something a little better than stock but after doing a search, I think that I'm going to go with an OEM style lifter. Thanks for your help Z95m6, you were all over it today.
no problem, if your stockers are fine just reuse them. I'm personally running Comp OEM replacements and when i called Thunderracing they told me they're all made by the same company.
Originally Posted by Mkos1980
The summit brand Hyd lifters have a crane part number on it. I run those. Not bad for $104.00
They are a VERY nice lifter. I run those lifters in BOTH my cars. I couldnt see spending anymore then that since both the summit lifters and crane are both made by Eaton.
Just checked sumitt. This is the P/N I came up with. SUM-HT214 It's $104 for 16 of them. Not too bad. They're listed as OEM replacements. Anyone running them with a higher lift cam?
Its just hard to belive those are the same exact lifters that comp sells that are literally twice as much. Not saying its not true. Just wish I could read something that says that.
Originally Posted by firebirdStud
if they are all made by the same company, then why would you not buy the crane ones, they are a lot cheaper!
Henson071
Dec 30, 2015 09:55 PM
Oh well, the rest of my valvetrain is Comp now.. soooo
