OBDII PCM in 94 formula??
Old Apr 3, 2006 | 08:46 PM
30696bird's Avatar
I have a friend who thinks he may have fried his PCM and I plan on letting him use my PCM just to start the car. If the car runs we'll get him an OBDI PCM. I also have a OBDI PCM I could let him use but I soldered the resistor INTO the PCM (so I could just switch the pcm's easily without touching anything else in my car). Can I use either of them just for testing without having to switch KS's?
Old Apr 3, 2006 | 09:01 PM
96capricemgr's Avatar
Re: OBDII PCM in 94 formula??
Either should work for that purpose though will throw a code/s. The OBD1 setup for the OBD2 swap would set a knock sensor code or the OBD2 one would set a KS, CPS and rear O2 codes
Old Apr 4, 2006 | 03:55 AM
30696bird's Avatar
Thanks, that's what I thought but had to be sure.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
